How do u clear u're corner lights
Old Jun 10, 2002 | 12:06 AM
bepoohbah's Avatar
7th Gear
I'm new to here, this is my very first post. and i really enjoy reading this site,
I was just wondering how do u clear the corner lights
is there a guild or step by step instruction to do it
Thanks a lot
Old Jun 10, 2002 | 12:48 AM
JLai's Avatar
Cause stock sux.
You buy the clear corners for $35.
Old Jun 10, 2002 | 12:58 AM
ChrisKelly5's Avatar
Acurazine OG.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1358054855
Old Jun 10, 2002 | 01:01 AM
JLai's Avatar
Cause stock sux.
Or buy them cheaper on E-Bay.
Old Jun 10, 2002 | 09:05 AM
keuka1's Avatar
There are a lot of threads on this so you could search the board but since I just put thease in this weekend.....
This is for the 1st generation
All you will need is a phillips head screw driver and about 20 minutes.
If you look at the amber stock units you will see a small hole on each unit facing the center of your car.
Stick a screw driver in and unscrew until the light is loose.
Gently push in on the light and the whole unit should come out.
You will have to disconnect both lights (by twisting them) and take all the hardware off(spring and screw retaining clip) and put them on the clear units.
Reassembly is a snap jut put the unit back in and tighten screw(s)
You may want to orebuy some new lights if you use Xenon bright lights...I am waiting for mine to come in and then I will do the whole prcedure agian.
Good luck
Old Jun 10, 2002 | 09:38 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Welcome!
The clears will really help to uniform the appearance of the front end!
Old Jun 10, 2002 | 10:36 PM
bepoohbah's Avatar
7th Gear
Thank you very much for u're help
u are all very friendly
Keep up the good work
mada51589
Jan 9, 2025 04:40 PM
ellisd03tls
Sep 8, 2015 04:17 PM
voigt
Sep 2, 2015 10:44 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
