How do I get at the red "alarm activated" light in the door?
Korean FIYAH!
I did a search but couldn't find anything....
I want to replace the red "security activated" led in the door with a blue one.... Do I have to remove the door panel to get at it, or does that little plastic panel pop off?
I don't want to try prying it off if it is screwed down internally.
Also, does anyone have a DIY for removing the door panel?
Thanks in advance.
Thanks in advance.
Originally Posted by J30A1vtec
ive got an even more important question . . .how do i turn it on .. .i bouht my car without the keyless entry . . .is that what i need?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
There was a diy posted on this before, I think you can pop out the little plastic box with a small flathead screw driver.
Originally Posted by Leon
the way to turn it on is to use the key and lock the door! also, isn't that lil plastic cover ( the part that covers the lil bulb) red? how would you make the blue bulb show blue throught that?
rockyboy
12-06-2022 02:29 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
