Hole in firewall
Hole in firewall
I am trying to install some fogs, and i have been looking but i can not find a hole in the firewall, and i dont want to take out the rubber seals surrounding any of the wires if im not sure. helppp!
I wrote a diy about this, you can either pop out one of the rubber grommets around the wires or cut a hole through it and run the wire through. I used the one right under the dash on the drivers side
i just sliced a little hole in that and took a piece of wire hangar...taped the wires to the end and shoved it through, carefully. then pull it through from the inside. works every time
Especially if you don't have heated seats, use one of the button locations already in the console
