higher compression ratio....
Old Dec 7, 2009 | 01:36 AM
acura_honda_30cl's Avatar
Ok i was wondering if or has been done, for the 3.0 to have a high compression ratio. And what has to be done for it to have a high compression, cuz i want to put a cam on the 3.0
Old Dec 7, 2009 | 08:35 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
https://acurazine.com/forums/search.php
Old Dec 7, 2009 | 09:31 AM
Blazin Si's Avatar
It depends on the compression ratio and cam you're considering. Do you have the specs for the cam?
Old Dec 7, 2009 | 01:31 PM
Well i want to put the cl-s cams...so wonderin wat has to be done, milled, port and polish or bore it out? Any input would be nice...
Old Dec 7, 2009 | 01:53 PM
(Mid-Atlantic)
The CL-S cam info has been posted on here a dozen times, why don't you search?
Old Dec 7, 2009 | 04:13 PM
OttaWacK's Avatar
less n00bin more g00glin
For someone like this OP, trying to do all this fancy crap...you really dont know shit about anything. For our sake, just go pay someone to do this shit for you. You seem quite incompetent and all talk.
Old Dec 7, 2009 | 06:50 PM
davzilla's Avatar
uh oh, team canada, on the prowl. lol.
btw. the 3.0 eats trannys stock. so making more power, not best idea. unless you have 10g's to blow. oh and say goodbye to your mileage and the ability to run 87 octane.
Old Dec 7, 2009 | 08:26 PM
Ey money aint a problem...and ottoshit fuck u, u could suck my filipino dick bitch!!!...excuse my french!! Had to let dat out....
Old Dec 7, 2009 | 09:24 PM
Cocoa's Avatar
2600lb CL
I would simply use CL-S pistons to raise the CR from 9.4:1 to 10.6:1
You can also use the newer RL pistons (would have to look up what year as I don't remember off the top of my head) to have a 11:1 CR. Although I know the RL's use a oil squitter which no CL's have stock. But a safe tune should be sufficient enough imo.
And yes, the use of higher octane (91-93 depending on your state) to help prevent detonation would be needed from that point on.
Any piggy back would do for tuning. No need for anything fancy as we can't alter timing (ecu does it on it's own and doesn't allow for any piggy back to override it).
As for the CLS cams, I know I made a thread in regards to it and where you should go to get it machined to fit your distributor.
OttaWacK's Avatar
all you have done is post shit. I doubt you have followed up on anything. Keep your tough guy attitude for the streets.
If anything, post some DIYs to what you have done. I would actually like to see some of the stuff you have done. It does appear quite extensive and would be a badass ride, unless you want to keep ninja about it. I dont want to bad mouth, I like to read about people builds, but all you do is ask questions. No harm, just build and post pics/vids.
Old Dec 8, 2009 | 12:14 AM
GhettoNinja06's Avatar
Skuuuurrrrrt!
How much do you think that would cost and how much HP you think is possible to gain with the pistons, port pollish, cam, and tune?
Old Dec 8, 2009 | 08:40 AM
(Mid-Atlantic)
Get out of here with that shit, this is your warning
joflewbyu2
Aug 18, 2019 10:38 PM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
San Yasin
Sep 29, 2015 10:52 AM
