HID Light Question
Old 10-11-2007, 10:46 PM
  #81
#GOBULLS
RyanCHICL's Avatar
Originally Posted by jfkhan
Hi RyanCHICL,
bump me at javedkhansaheb@yahoo.com, the same happened with memine didn't fire as well i wrote to the guy who sold me he sent me instructions whihc I can forward it to you. Basicall you have to switich the polarity like the negative and positive,this you have to on the the balast side where the cable connects the balast to the stock wiring. I can forward you the instruction if you email me. it is pretty easy you can do it with juts a pin tool or some thing.
Hope this helps, also if the HID bulb is a 9006 base bulb it should fit the socket, don't use to much forac as you might crack the fiber but try it it should fit mine fit pretty esaily.
Hope this helps.
Thankx
Javed
Hey thanks for trying to help me out. I got frustrated with it so i took everything apart and put back in the box. I hope i didnt ruin the bulb but I think im ok. But I called up my local mechanic who does work on all are cars. They also do tuning stuff too. They said they would be able to install them for me. So tomorrow im going to drop the car by.
Old 10-11-2007, 11:57 PM
  #82
DoubleSh0t's Avatar
Run.
Cons? Fire in your engine bay.
Old 10-12-2007, 12:33 AM
  #83
lifeenjoyer's Avatar
http://cgi.ebay.com/ebaymotors/HELLA...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/PILOT...QQcmdZViewItem
What about these???
From the feedback here on AZ, its seems like Hella and Phillips were recommended by a lot of you on here....but the prices that its listed for on ebay, phony/knock-off??
Old 10-12-2007, 09:04 AM
  #84
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,461 Likes on 3,055 Posts
What about these???
Those look a little better, I would be hard pressed to believe that is really a hella kit, hella is expensive stuff
Old 10-31-2007, 05:39 PM
  #85
7th Gear
greggy's Avatar
i want to buy plug n play also but which one ? i dont have many for kaixen kits or something like that i have just around 150$..
9006 for my cl 1999
Old 10-31-2007, 06:04 PM
  #86
6spd FTW
Tehvine's Avatar
I think the ebay PnP HID's I had gotten for my accord were MKS? They were 150 shipped and I had them in my Denji projectors that the previous owner put on the car. Not a spectacular cutoff and the light output of the H3 halogens that were in there sucked badly. Never got pulled over for them and only flashed twice after using them for about 1.5 yrs. 6000k Color temp sucked in the rain with those lenses though... All I could see was the lines and the rest just bounced off the wet pavement. Going to jack the HID's out of the accord for fogs in the new CL.
Old 11-01-2007, 01:37 PM
  #87
7th Gear
greggy's Avatar
what else guys ? ???
Old 11-01-2007, 03:57 PM
  #88
2.2CL owner
cl-baller201's Avatar
Hey is it really complicated to install projectors ? .. Takin' the bumper off seems like a real bitch to do.
Anyone?
Old 11-01-2007, 08:14 PM
  #89
(Mid-Atlantic)
Anyone?
Installing the projectors is a real bitch, I recommend you have a second set of headlights to hack up so you don't mess with the ones that you have on the car, it also enables you to take your time
Old 11-02-2007, 02:39 AM
  #90
I'm in the midst of making an attempt to create a pair of retrofits myself....
Will order a pair of seperate headlights.
Yo 97blackackcl, I know you went through many different projectors. Just wondering how it took to install each of those individual ones, well an estimated average time for the entire process?
Old 11-06-2007, 11:12 PM
  #91
#GOBULLS
RyanCHICL's Avatar
Hey guys, Ive had my HIDs installed for a couple weeks now and i recently noticed that when I turn my HIDs on, the radio reception goes down significantly, i thought my antenna was going bad at first, but the radio is clear again when I turn the HIDs off. Any suggestions?
Old 11-06-2007, 11:31 PM
  #92
DaInFaMMuS1's Avatar
9006 for my cl 1999
I got my HID's from a local guy on .com named franklin. They've been pretty good, just had 1 issue with a bad ballast which he replaced for free (which i probably blew myself trying to install it on my own and messing up the wiring haha). i paid 130 for 3K 9006 HID's for my headlights. All of us over on that board get our HID's from him and no have complaints at all. He's a Jersey guy but i believe he will ship. Just go to .com and scroll down to sponsors and click Bright Lights Inc.
Old 11-10-2007, 10:28 AM
  #93
ContemporaryLegend's Avatar
Plug and play 9006 HID kit, our vendor excellerate sells kaixen kits which are pretty much top of the line. And THIS is the place to ask all those questions
Well thats good to hear that the 9006 kits fit, my buddy asked me last week if I wanted to buy his kit from him in box, unused for 20$ of PIAA's, which I heard are a great brand, so Im gonna go ahead and buy him, how does the install of these work?
Old 11-10-2007, 11:03 AM
  #94
(Mid-Atlantic)
PIAA is a great brand, if it's a real kit and not just bulbs that's a steal for $20. All you do is plug and play
Old 11-11-2007, 12:54 AM
  #95
#GOBULLS
RyanCHICL's Avatar
Does anyone have any suggestions yet?
Old 11-11-2007, 10:54 AM
  #96
(Mid-Atlantic)
^^ Get a new alternator and battery
Old 07-21-2008, 04:37 PM
  #97
purple3.0haze's Avatar
Originally Posted by klepto
theyre pretty simple. just a few extra connections, otherwise its just like swapping out any regular old bulbs. Although id reccomend getting an upgraded wiring harness, which will require you to run extra wires from the battery. The "converter box" (ballast) should come with double sided tape and zip ties. make sure its mounted somewhere good so that it doesnt clank around when driving.
you can refer to this thread
https://acurazine.com/forums/showthread.php?t=172106
where can i find the upgraded wiring harness that he speaks of.
Old 07-22-2008, 08:42 AM
  #98
(Mid-Atlantic)
ebay, I also have a set I could sell if I can figure out what box they're in
wusty23jd
09-24-2015 11:41 AM
pozebly
09-23-2015 07:30 AM
JnC
09-11-2015 06:06 AM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
voigt
09-02-2015 10:44 PM
Quick Reply: HID Light Question
