Hid 9006 Question..
Old Apr 13, 2003 | 02:32 AM
nippon_wa's Avatar
nippon_wa 2.0
Hid 9006 Question..
I'm looking for getting those lights
How much should I spend for those?
and.. what brand should I get??
or.. are there any other lights???
THanks
Old Apr 13, 2003 | 03:34 AM
tw1112's Avatar
if you're going true hid I would go with philips/hella ballasts and philips or osram bulbs. I personally would go no higher than 6000k. Look to spend around 350+ for a complete kit with relays and everything. Beware of knockoffs.
Old Apr 13, 2003 | 03:56 AM
nippon_wa's Avatar
nippon_wa 2.0
If I get hella ballasts, is that easy to install??
I think.. i have to take all the lights out and.. cut something..
right?? hmmm.. i dont' know if it's good or not..
I just wanted to get HIDs and... just put it in... hmmm
any other suggestions??? Thanks ~
Old Apr 13, 2003 | 09:39 AM
d5c5b's Avatar
DOOKS of hazard!!!!
you can get hid bulbs and not do ballasts from what i understand.....theyre around 70$ a pair and im not sure on good brands to look for...someone else?
Old Apr 13, 2003 | 01:05 PM
SickAcura's Avatar
if you just want hid lights check out PIAA they are top of the line in my opinion
Old Apr 13, 2003 | 04:47 PM
tw1112's Avatar
Eh...you can't just plug in true hid light bulbs into your stock wiring because the ballasts are needed to give the xenon gas a bump of power to start them off....then once the gas is "charged" up the lights only use 35w rather than the stock..55w(?)
PIAAs although bright are not nearly as bright as true HID's.
No you don't need to take apart the housing to do the kit. If you do a custom install HIDs from another car then maybe...but if you are buying a 9006 conversion kit then no. You find a place for your ballasts, install the wiring and relays and such so that you don't keep popping fuses, plug the light bulbs in and you are ready to go. Install, depending on your expertise, should take anywhere from 40min - 1.5hr+
Old Apr 13, 2003 | 05:12 PM
VXCL's Avatar
AWD Torque Monster
exactly. a kit will be plug and play so very easy install
unless u do this
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
