Hey anyone know what this sound indicates?
Hey everyone,
I'm getting a squeeking sound on the front driver side, it happens everytime I go over a bump, I'm not sure what it is, any idea's, and if so how much will it cost to get fixed? I push on the front bumper when the car was parked and shut off and I could here the squeeking sound, but it's much like when the car is driver, rather embarassing really, any help guys?
I would suspect the stablizer bar (anti-sway bar to some) bushings are the cause. They get dry w/ age and when you go over a bump the bar twists in the rubber bushing. You can loose the bushing support bracket (one on each side) and force white grease into the bushing to eliminate the squeak.
If you lay on the ground, put your hand on the bushing, and have someone push the suspension up/down you should be able to feel/ hear the squeak from the bushing to confirm the source of the noise.
good luck
good luck
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by STL+3.0CL
Struts
Old School Ridin Clean
Originally Posted by Wannarace62188
never eliminate ball joints either.. Had that squeek in my old car and one day driving the ball joint broke.. not fun..
Yep ball joints are usually the cause. If your strut is bad you would notice your car boucning every wherer when u do hit a bump
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
