helppp
I can give you quick instcutions:
Remove the 2 screws inside the tire area, below the fender.
One is a 5/16 or a phillips
The other is a phillips
After that, remove the clear/amber corners using a screw driver inside the side hole, then take that off
Inside that, there should be a size 12 bolt....its kinda goldish/bronze color. THen there's another toward the inside, in the lower grille (you'll see that too)
Then under the car, there are a few things....I kinda broke them...owell tho
After all the nuts/bolts are off, you pull out the sides (where the screws were), then u push the bumper down, then u pull.
It should come right off...
This may help.
http://public.fotki.com/dustbuster4/a-clcom/bumper.html
Click on "Get Original Uploaded Photo" for a huge pic.
Micheeellee
Aug 28, 2012 12:36 AM
My07Typ3-S
24
Sep 12, 2011 12:09 AM
AK23
Apr 14, 2011 09:43 AM
