Help! Transmission problem after changing transmission fluid
Old 03-25-2005, 07:23 PM
sonicleo's Avatar
I just changed the transmission fluid for my '97 CL at an auto mechanic on Tuesday. After that, i didn't even touch the car. But today, the transmission suddenly became quite weak. At first, I was able to change among the lower gears, but the transmission refused to change gear after a while. Every time I pushed the accelerator pedal, the tachometer went over 4K rpm without changing gear, just like the shifter was on 'neutral'. Has anyone had the same problem before? What problem is it probably? Thanks in advace.
Old 03-25-2005, 08:55 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
ouch. start looking for a new tranny. our trannies are weak as hell. mine went out the same day i had a tranny service done at the oil change shop. :ghey:
Old 03-25-2005, 11:37 PM
how handsome I am
agranado's Avatar
:surrender :surrender :surrender
I think that just about sums it up. sry man. Hope for the best.
-Alex
Old 03-26-2005, 11:08 PM
wilp99's Avatar
first off what kind of engine do you have 2.x or 3.0? second, make sure u put enough in there. it sounds like thiers either too much or too little fluid. check the level with the car not running like the directions say. and make sure u used the honda atf fluid from the dealer. and not the automatic transmission fluid dextron III.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Aleax
09-11-2015 11:31 AM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Help! Transmission problem after changing transmission fluid
