Help SacTown Cl on Jack Stands
No Show All Go
ok... I am with out air compressor or air tools only hand tools.
The bolt that holds on the rear driver side strut is over torqued. Towing is not an option and I am stubborn. I was tring somthin in the shop yesterda and wont have access to the shop for 2 more weeks. I added a spacer on the back strut to try and level ou the front and back. Now my breaker bar cannot free the bolt. I tried real hard and the bar slipped and I almost stripped the bolt so... Any tricks?
If any one has access to a compressor and a torque wrench in the greater sacramento area PLEASE HELP. I refuse to ride with my backend 3 1/2" above the wheel well. even the coilovers wont drop it enough. All I need is a drive by unbolting something that would take 30 seconds. Id even pay for the gas to come to me
If you can help PM me or even email me anytime is good 11pm to 1pm is all I canhandle cause my girl is driving me to work now
No Show All Go
Originally Posted by mclarenf3387
The one on the bottom?
I had a BAD experience with the rear lower shock bolts
how handsome I am
you had a bad experience with those bolts?
guess what?
so did about 95% of every CL owner who has tried putting on aftermarket struts.
Be prepared to buy a new one (and quite possibly a bushing to go with it) once you get it off.
they arent very expensive at all from the dealers I think... cant go over 10$ methinks?
hopefully you wont need to buy one. Good luck (and make sure you got plenty of wd40? for that sucker)
-Alex
guess what?
-Alex
No Show All Go
someone told me that Ice feeling spray that you use on cuts that gets real cold, if you spray that on the head of the bolt, you can get it to cantract from the strut a little and it will loosen up
guess what?
-Alex
guess what?
-Alex
The bushings are like 25 each.
The bitch is having to put the new bushings in
1 Post
wtf are you guys talking about? I had no trouble with any bolts on the car except a tiny bit of trouble with the rear lower bolts. breaker bar + a jack under the part the bolt goes through to relieve pressure on teh bolt = easy win.
you guys lose.
edit: oh wait, you mean the rear ones. sooo yeah, use jack stand as said, then I used the X bar I used to remove the lugs on one side, and just a ratchet on ratchet on the other side, and turned each in opposite directions at the same time, one with each hand.
you guys lose.
NAWWWWSSSSSS
1 Post
Originally Posted by Cali3.0
you serious?
no lie
buy a propane torch.... heat up the metal till its orange and blazing hot throw the socket on it w/ the breaker bar and it will come off like butter.. swear to god..
in minnesota we live and die by torches ask clman (mechanic) and this even works for me.. about every time
how handsome I am
Originally Posted by shineynitelite
no lie
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
