Help pulling abs codes
Old Aug 3, 2005 | 10:23 PM
John07's Avatar
9th Gear
Question Help pulling abs codes
Can anyone please tell me how to pull the abs codes on my 98 3.0cl? The abs light come on and will not go out. I am shure it has stored a code. I have heard that you can short out the service connector that is located under the glovebox and count the flashes of the abs light. I need to know if this is possible or will it mess up the abs computer.
Thanks, John
Old Aug 3, 2005 | 10:28 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
let me find the user that had it on his site
Old Aug 3, 2005 | 10:35 PM
http://home.insightbb.com/~niedejb/
click on resources and then you can read and its simple
hope that helps
Klepto: if you see this please add this to the FAQ cause this is a VERY HELPFUL site
Old Aug 4, 2005 | 01:02 AM
98atlcl's Avatar
Did you check your braked fluid level. If it is low you will get an abs code.
Old Aug 4, 2005 | 05:22 PM
klepto's Avatar
hope that helps
sounds good, i'll take a look at it, I remeber this guys car...turbo f22
Jamus22
Jun 11, 2023 10:08 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
