help please
Old Apr 27, 2007 | 09:50 PM
blkak97's Avatar
help please
ok im trying to install the s7 aftermarket gauges and the screwholes arent lining up correctly so i cut a little of the gauge so it could fit, will this affect the "glowing" part?
Old Apr 27, 2007 | 09:57 PM
AznX TL's Avatar
where is....
unless you cut the wires i doubt it, if you already cut it why dont you find out?
Old Apr 27, 2007 | 10:01 PM
blkak97's Avatar
cause the inverter for it is on backorder so i dont have it to hook everything up, im just tryin to put the gauges on while i have some free time, good idea though
Old Apr 27, 2007 | 10:11 PM
blkak97's Avatar
do i even need an "inverter" or can i just run all of the wires together
Old Apr 27, 2007 | 10:39 PM
hornedfrog2000's Avatar
B A N N E D
I'm sure they are all just acc 12 volt signal wires. I wouldn't do it, but hey its your car.
Old Apr 27, 2007 | 10:49 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You need the inverter, which part did you cut? are the screws real far off? Did you get the 94-97 accord gauges?
Old Apr 27, 2007 | 10:50 PM
AznX TL's Avatar
where is....
the inverter has resisters and such inside that are pretty important.
Old Apr 27, 2007 | 10:52 PM
(Mid-Atlantic)
Old Apr 27, 2007 | 11:58 PM
blkak97's Avatar
the screws were maybe half a screw off on both sides of the needle on all of the faces except the spedo and all i did was make a notch on the side of the screw hole to "fit" the screws in and yes i have the 94-97 gauges
Old Apr 28, 2007 | 03:16 AM
agranado's Avatar
how handsome I am
those shits were pretty tedious to install and take out... but all you had to do was mess with it for a bit and it fit.. at least mine did
Old Apr 28, 2007 | 06:31 PM
blkak97's Avatar
damn oh well
at least i didnt break any gauges
Old Apr 28, 2007 | 08:57 PM
CLpwner's Avatar
Mmmm...
damn oh well
Debadge your avatar bro...
Old Apr 28, 2007 | 09:01 PM
(Mid-Atlantic)
Old Apr 28, 2007 | 09:14 PM
CLpwner's Avatar
Mmmm...
yea...
