HELP! motor problems? maybe CPU?
zZzz
okay guys i been getting alot of information and ideas from this forum, thank you all. however i been having this problem for awhile now. the check engine light comes on. second, it only comes on when my motor fails to rev pass 3k rpm. i dont understand it and cant locate the source of the problem. it usually happens when im at a stop light; ill usually shut off the motor and start it back up then it's back to normal with the check engine light still on. i dont know im starting to lose faith in my cl... i hope it's not something major... besides HELP ME! im soo lost and frustrated and lost...
![Pound](https://acurazine.com/forums/images/smilies/pound.gif)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like your idle control valve
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by FULLRACE
core processing unit ?
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
![Soopa](https://acurazine.com/forums/images/smilies/soopa.gif)
But I assume you're talking about your ecu
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by lnsyone
oregon trail
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
zZzz
new probelm occured! f**K! when i was driving and stopped at a light i turned off the a/c and my car just died. i tried to start the car up and it wouldnt start up. so i turned on the a/c and then tried again and it started... WTF is going on with my car?!?! help!
Acura loyal for 93mo/109k
DRK, here's some codes for your 2.2CL.
http://www.troublecodes.net/acura/22cl.shtml
I don't see a P0136, but that's in the area of the O2 sensors. It seems more likely the P1361 (TDC sensor) would influence your RPM's. Could be something as easy as a bad connection.
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by DRK
thank you Nakamichi. you provided great info. does anyone know where i can get a crankshaft position sensor besides autozone?
or www.acuraoemparts.com
