Help Keyless Remote!
Old Nov 8, 2003 | 01:46 PM
r0dz0r's Avatar
Forced Induction Spec.
i just bought one on ebay and i got it right now how do i program it!!!!!!
Old Nov 8, 2003 | 02:01 PM
ninja's Avatar
fantabulously chillaxin
take it to the dealer
Old Nov 8, 2003 | 02:23 PM
uiskibum's Avatar
its paid for
Programming the Transmitter
NOTE:
Entering the programming mode cancels all learned transmittter codes, so none of the prviously programmed transmitters will work. You must reprogram all the transmitters once you're in the programming mode. The system accepts up to four transmitters.
To keep the system from exiting the programming mode, complete each step within 5 seconds of the previous tep, and program the transmitter s within 10 seconds of each other
1. Turn the ignition switch ON.
2. Press the LOCK or UNLOCK button on one of the transmitters (A non-programmed transmitter can be used for this step.)
3. turn the ignition switch OFF.
4. Repeat steps 1, 2, and 3 two more times with the transmitter used in step 2.
5. Turn the ignition switch ON.
6. Press the LOCK or UNLOCK button on the same transmitter. Check that the power door locks cycle to confirm that you're in the programming mode.
7. Press the LOCK or UNLOCK button on each transmitter. (You can program up to four transmitters per vehicle.) Check that the power door locks cycle after you push each transmitter button, confirming that the system has accepted the transmitter's code.
Turn off. Pull key out.
If just replacing the battery sync the transmitter to the system by pressing the LOCK or UNLOCK button six times
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
