Help with indiglo Gauges
OKay I was reading the instructions on here for the gauges and I didnt get very far!!! I cant get the factory dimmer switch out...the cruise control came out easily. I got the brackets out but its still stuck in I didnt want to keep pulling it because i didnt want to mess anything up! and whats the deal with hookin them up to the factory dimmer some say yes some say no. how else can you hook them up!!!?? Even if it has its own switch
Did you already pull the guage cluster out? You can pop the dimmer out from the back if need be. The dimmer has 2 clips on each side that hold it in.
I hooked mine up to the dimmer, no problems. Your not going to use the dimmer once you get the indiglo's on, so why not use them??
Yeah, that's because the wiring harness doesn't have enough slack to pull it out. Your gonna have to try to disconnect it before your able to pull it all the way out. Can you get to it from underneath? Maybe push wiring harness with the screwdriver while pulling on the switch from the front?
Sorry, it's been a long time since I took mine out.
yeah, when i did mine the dimmer wouldnt come out because the wires werent long enough. i ended up breaking the dimmer control because i got real mad. i also ended up breaking the glass covering, and the fuel and temp gauges. so i ordered new parts and its all in now.
mrkingstonvi
02-22-2016 01:53 PM
