help with driver door
Old Jan 19, 2005 | 10:47 AM
STLUSMCH's Avatar
kept the beast
the other day i go to open my driver door and it wont open from the inside so has this happened to anyone if so how easy is it to fix and how much
Old Jan 19, 2005 | 11:00 AM
d5c5b's Avatar
DOOKS of hazard!!!!
sounds like you need to throw that piece of junk away! ahaha- whats up buddy!? long time- i'd say take the door panel off and see if its something stupid just stoping the door from opening. the latch is all mechanical so its not an electrical problem, unless the door isnt unlocking...then it might be over your head! good luck regardless!
Old Jan 19, 2005 | 05:46 PM
97Cl22's Avatar
Comrade Stalin
I had this problem. There is a small metel piece on the door handle (behind the door panel, helps to take that off) thats connects the handle to the rod that actually opens the door that broke on me. So i would just pull my handle and nothing would happen. $30 and a new handle assembly later, the problem is all solved.
Old Jan 20, 2005 | 05:02 PM
STLUSMCH's Avatar
kept the beast
where did u buy the assembly
tman570
Jun 11, 2019 07:56 AM
tj19855
Dec 5, 2016 09:16 PM
VA2000TL
Oct 2, 2015 08:26 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
