HELP!! BRAKE Piston!
Can someone tell me how to install the brake piston into the calipur?? The piston won't go into the calipur by just trying to push it in.. Do i have to use a C-clamp to clamp the piston into the calipur and then install the calipur?? How do I do this... HELP can't go to work!!
Swaps? $3000 for 50HP? :(
Front or rear?
The fronts push in but the rears have to be turned in like a screw.
Try taking the cap off the master cylinder to let the fluid back in it easier.
Work safe avatar bish :D
if it is the rear grab a big screw driver and put it in sideways, then turn the piston back in. also make sure you bleed the system to keep air out.
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
