Headlights
Headlights
Where can I find a good price on headlights for our cars? I have tried to restore them with that stuff they sell in the stores but no luck getting them clear again. Should I try to take them to a pro and get them restored?
Ive had great luck with turtle wax headlight restoration kit. it comes with everything you need. the drill attachment , 4 gritts of sandpaper , a wet sanding lubricant , the final step polish and a lens sealing wipe. Just take your time on the wet sanding their are 4 diffrent levels and its key for crystal clear lenses. its agood idea to use masking tape to protect your paint. Good luck dude . don't let the "pros" take your money
I have used two different type of kits. One is just some type of polish and sealant and that didn't work very well but the one that hooked to a drill and had different grit sandpaper did a very good job. There are other types that hook to a drill I haven't tried so I can not comment on them about how well they work but I know the one with the sand paper does a good job. You can probably get like a 1800-2400 grit wet/dry sandpaper and take the top layer off yourself and then use the polish and seal it and it work just as good as what I am talking about
AmplifiedDetails
09-24-2015 02:55 PM
