Headlights
Old Sep 19, 2004 | 03:54 PM
Green97Beast's Avatar
Headlights
Hey people - My headlights have become quite cloudy since ive gotten my lights and im just wondering what i need to clean them up. Someone told me acetone works but then someone else told me that it doesnt work too well at all. This is probably a newb question for all of you experienced CL owners but I'd really like to know the best way to clean my headlights. Thanks peeps.
J
Old Sep 19, 2004 | 04:19 PM
Hobo's Avatar
Flap.
there was a post about this not too long ago, do a search.
the solution involved sand paper and a buffer if i remember correctly
Old Sep 19, 2004 | 05:02 PM
lnsyone's Avatar
CL 4 LYFE
My friend used this ss/metal polisher and it worked pretty good. It comes in a polished can.
Old Sep 19, 2004 | 06:22 PM
1StGenCL's Avatar
958 & 991
for light stuff you can actually use toothpaste because it contains a mild abbrasive but for deeper pitting and clouding you will need to wetsand. I dont know the grit at the time but i know it has been discussed Good luck
Old Sep 19, 2004 | 06:33 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
Originally Posted by Green97Beast
Someone told me acetone works but then someone else told me that it doesnt work too well at all. Thanks peeps.
J
Ascetone DOES NOT WORK, DO NOT USE IT AT ALL!!!
This will ultimatly make your headlights even worse, they put a glaze over the headlights and make it even more cloudy, ive tried and skrewed one of mine up a while back when i did my first projector conversion
Best thing to use is some stuff called GooGone, it works great and it is a great product. also you can use the toothpaste technique, use some plain baking soda toothpaste and rub in circular motions and then clear off with some warm water
Hope this can help ya out, if you need instructions on how to take apart your headlight do a search for it you will find many people explaining how to do it, ive done a write up, VXCL has done one many of times and a coupld of others as well
Joe
Old Sep 19, 2004 | 07:32 PM
baka_t's Avatar
The movement has started
I wet sanded mine, with 350, 1000, 1500. Put some pretty good scratches in the lens. After, I used heavy duty rubbing compound, then polish with scratch remover. I heard the best thing to use is the meguiars plastic cleaner, polish with a d/a polisher.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
