H22a HELP!!!! URGENT
Old Aug 28, 2002 | 08:30 PM
turbotk's Avatar
I am doing the swap right now and the driverside mount is totally frigin different here. I got a 2000-2002 motor and if anyone knows what i am talking about please post.
Urgently
Old Aug 28, 2002 | 09:06 PM
Bdog's Avatar
Not Registered
Don't you need a Prelude mount there? That is what I thought.
Its the 5 gen swap, not sure of the diff.
http://www.h22a.org/5gswap.htm
d98clturbo's Avatar
Old Timer
the cl mount should work...that is what i am using in my car
Old Aug 28, 2002 | 10:01 PM
dcsquirm88's Avatar
This motor basically bolts in using the all the CL mounts except for the drivers side mount. A Prelude mount must be used, and the metal bushing that holds the bolt mounting it to the frame must be shaved down slightly to fit between the brackets on the frame, you will see when you do it.
Try doing that and see if that helps.
Old Aug 29, 2002 | 05:15 PM
turbotk's Avatar
I ahve the mounts for both cars but neither works. I have to use my cl mount and then weld one side to the actual motor. That is the only way. uNLESS they gave me the wrong mount from the prelude. Remeber it is a 2002 prelude . i don't know if that year is different or not.
But anyways i figured it out and the motor will be done tommorow.
Thanx
Old Aug 29, 2002 | 05:23 PM
Bdog's Avatar
Not Registered
Yea, not sure of year model changes, but hope you get it working. Can't wait to see some pics.
Old Aug 30, 2002 | 03:12 PM
Woodsdaddy's Avatar
Everybody Wang Chung
i want to see some pics too
kingmarc01
Feb 17, 2005 08:34 AM
Clean_CL
May 6, 2002 04:24 PM
dcsquirm88
Mar 21, 2002 11:42 PM
