H22a
Old Dec 29, 2003 | 01:43 PM
Light_Speed's Avatar
H22a
Hey I am really close to get a H22A but I want to know how easy is this swap.
Is it a direct swap??
I am getting it from www.jdmsource.com but he is unsure how the swap may be because there hasnt been many CLs
Can anyone help me out.
thanks
Old Dec 29, 2003 | 01:53 PM
joeyjoejo's Avatar
Wow a fello Canadian. Props to the Canadian Peeps. Where are you in Canada? JDM?=Edmonton?.
Old Dec 29, 2003 | 01:54 PM
Calgary
Old Dec 29, 2003 | 01:55 PM
Hey since your in Alberta you should check out www.beyond.ca
its a calgary based forum
Old Dec 29, 2003 | 02:00 PM
lnsyone's Avatar
CL 4 LYFE
its a direct swap.
Old Dec 29, 2003 | 02:01 PM
Originally posted by lnsyone
its a direct swap.
thanks
anything I should worry about??
Old Dec 29, 2003 | 02:36 PM
lnsyone's Avatar
CL 4 LYFE
Originally posted by Light_Speed
thanks
nah, it will be g. ill let you know in a few days, when i get my car back.
Old Dec 30, 2003 | 12:10 AM
d98clturbo's Avatar
Old Timer
it is a direct swap ...the hardest part will be the wiring for the ecu...what year motor are you getting?
Old Dec 30, 2003 | 01:47 PM
Im gettin a 95
Old Dec 30, 2003 | 01:52 PM
rmh3093's Avatar
Pass the dutchie!
dont u have to get at least the year engine your origional engine was
Old Dec 30, 2003 | 01:54 PM
Mark Davison's Avatar
Big Block DOHC Type-R
You just need an obd2a to obd1 jumper harness. Or if you have a 98-99 you need an obd2b to obd1 jumper. Then you can run the obd1 p13 ecu that is for H22's.
Old Dec 30, 2003 | 02:08 PM
Outlaw's Avatar
CL smashin
If you want to stay smog legal in California with the DMV, then yes (Not sure about other states).
If you only want to PASS the smog test, I've read from Mark Davison that you should just get a USDM H22A.
Read here for more info.
Old Dec 30, 2003 | 02:21 PM
Duece's Avatar
LA`s Top CL
if you can do the wiring yourself it would be koo my cousin did mines for me at his shop i think my mounts had to be adjusted but thats pretty much it............any h22 will swap right in from what im hearing ob2 will pass smog here in cali but ob1 wouldnt....
Old Dec 30, 2003 | 05:38 PM
Leon's Avatar
if you are getting a 95 H22A, for the the wiring you gonna need to move the "crank shaft positioning sensor" and the "top dead center sensor" over to the distributor (if you need a diagram for that I can make one and give it to you, just finished mines the other day). Also you're gonna need a drivers side mount shaved down (very easy). One more thing, is your car stick or auto, and if it's an auto do you plan to leave it auto? If not then you're gonna need a lot more shit!
Old Dec 31, 2003 | 01:50 PM
thanks
maybe you can send it to silverxtc1@yahoo.com
my car is auto and I am planning to leave it at that
any idea how much for it to be installed??
im paying 2200 Canadian for the engine and the guy said around 700 canadian for the install but he wasnt sure about that
kingmarc01
Feb 17, 2005 08:34 AM
hungy
Oct 24, 2002 05:28 PM
senile32nd
Feb 25, 2002 01:58 PM
hungy
Nov 13, 2001 09:50 PM
f0de
Jul 15, 2001 04:35 AM
