H22 owners, question?
My H22 is obd1, I would like to know, (from those that have done the swap) how did you connect your harness to the distributor or did you use the prelude harness? My engine is ready to be dropped in!
Originally posted by d98clturbo
use the stock harness just add the wires that you need...what is it 3 or 4 wires
Trailblazer = SUCK
cut the two plugs off your lude harness. Now you have to (this is real fun) get the wires for the crank angle sensor and the cylinder position wires over to the distributor area because on the f22 they were located over by the crank pulley. Now just use a helms manual or eqivelent to find out what wires to connect together from the lude plugs and the wires on your f22 harness. If you are still in the dark on this, ill try to go downstairs and take a picture of the wiring diagram i drew when i did it. Id take a pic of the wires themselfs, but my car is still in the shop
IIDXholic
10-08-2015 07:53 AM
