H22 crank pulley bolt
I was wondering, when trying to loosen the crank pulley on my h22 does go clockwise or counter clockwise? the thing is like super tight!
Old Timer
you have to turn it counterclockwise... i remember when i took mine off it was a bitch...
there is a special tool that you will need to take it off
or you could do what i did..this will require you having some help
put the socket on the bolt make sure it is in a good tight position so it wont slip off, then put it in reverse and push the car backwards (make sure you are pressing the clutch) then when you get up to speed pop the clutch that should loosen it...if it doesnt do it again
acuratl26
04-23-2020 07:30 PM
