h22
Old May 10, 2004 | 04:21 PM
feildy00's Avatar
busted
h22
other than the odb1 to odb2 conversion-what is the difference between a 92-96h22 and the 97-00 h22- if i get a 97-00 does anything else have 2 be changed
Old May 10, 2004 | 04:26 PM
HyDrOpOnIkToKa's Avatar
HOOK EM HORNS
nothing has to be changed if you have a 97-00 h22, if u have the f23 or f22 that is
Old May 10, 2004 | 08:31 PM
d98clturbo's Avatar
Old Timer
the wiring still has to be redone..regardless of what year the h22 is
Old May 11, 2004 | 12:04 AM
RippinRide's Avatar
you need a new wiring harness? or custom?
Old May 11, 2004 | 09:11 AM
d98clturbo's Avatar
Old Timer
use your stock wiring harness...it just has to be modified a bit
Old May 11, 2004 | 11:00 AM
-=DjPharmacy=-'s Avatar
A-CL CrAckHeAD
hey d98cdturbo - since you have already done it - was it easier to modify the stock harness or would it be better to run a new harness - JGEngine Dynamics told me that i will be using a civic harness with my new hondata ecu! I KNOW you know what your talking about - thats why i am asking you! Got a top secret project that is about to be unvailed shortly!! I may come to Tampa to show you before anyone else gets to see it!! Hit me back
Old May 11, 2004 | 11:47 AM
Duece's Avatar
LA`s Top CL
i used my stock harness....jes had to redo everything
Old May 11, 2004 | 12:22 PM
Mark Davison's Avatar
Big Block DOHC Type-R
The only reason your stock harness is the best to use is because it plugs into you chassis harness. A b16 civic harness is very simillar to what will be needed.
Old May 11, 2004 | 09:44 PM
d98clturbo's Avatar
Old Timer
i would say still stick with the stock cl harness...it will go alot smoother for you...give me a call 813-390-5059 ..i will be in o-town in the next couple of weeks my new job is sending me there for a 2 week training course
d98clturbo
Dec 2, 2007 01:47 PM
d98clturbo
Dec 28, 2005 01:56 PM
d98clturbo
Mar 25, 2005 08:05 PM
BLACKOUTCL
Oct 26, 2002 03:07 PM
billyg
Aug 26, 2002 05:06 PM
