Grounding your amp?
Grounding your amp?
I hooked up my system today and apparently the bolt in the truck is a bad ground, my amp just shuts off if i turn it up to like 12 volume on the deck. Anyone have a successful ground they're currently using?
sounds more like a fuse thats too small. eather way i grounded my amp to a bracket in the trunk with a bold and i sanded the paint away from the grounding point.
Where the stock rear speaker screws come through into the trunk is where I grounded both my amps. I just used a dremel to get the paint off around it, and then found a small nut to fit on that screw...there you have it. It has worked well for me.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by LCARUCA 97
you have yourself a short my friend. check and make sure the amp isnt a pos.
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
