grounding question
grounding question
ok so im wiring an amp and i got the power wire through the fire wall
and all that stuff but i dont know were i can ground the amp. So if u have subs and anamp what did u ground it to?????
Get a self-drilling bit screw and just screw it into the frame of the car, alot of people do that or either bolt it up to a bolt already placed in the car. As long as the surface is clean of paint it should be fine.
I searched long and hard and found the best place to ground is one of the bolts on your shock tower, behind the carpet, gets the best ground, I have 2 amps and 2 caps grounded off of there.
Originally Posted by Pooner
ya u saw that is it ok if i screw that out to put the ground in i was afraid that it would
mess something up.
mess something up.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
