gotta quick question...
Old Mar 14, 2002 | 09:10 PM
Sleeper-S_RENAMED's Avatar
7th Gear
i been noticing a weird noise coming from my car. it only happens when i roll over a bump. i can hear metal scrapping as the car is bouncing. i checked the brakes and they look okay. any suggestions on the cause?
thanks
Old Mar 14, 2002 | 09:15 PM
Bdog's Avatar
Not Registered
bad shocks
Old Mar 14, 2002 | 09:17 PM
7th Gear
Originally posted by Bdog
bad shocks
i was thinking that. but i only got 30k mile in it. sholdn't shocks be good for more than that? anyways... is it covered under the warranty?
thanks again
Old Mar 14, 2002 | 09:22 PM
Bdog's Avatar
Not Registered
I could be part of your exhaust system rubbing. I know it does have some coils that make your system flex. Maybe it is rubbing somewhere when your suspension moves. I just thought of that one.
Old Mar 15, 2002 | 08:29 AM
limequat's Avatar
Actually, the exhaust thing might be a good call. I have this problem on my 97 2.2. If you check near the center of the car in the tunnel, there should be an almost 90 degree bend in the exhaust. There is a mount right on the bend. The mount hanger protrudes dangerously close to the outside radius of the bend. On my car (and presumably others) the exhaust will swing upward after hitting a bump and thwack the end of the mount. It's actually left a mark on my car...
I haven't come up with any ideas for a fix - other than wrapping it with that fix-a-muffler-tape
Also, check your decklid - make sure the striker doesn't need to be adjusted down.
Exhast heat shields are notorious for making weird sounds. Some quality time under your car will tell you if this is the problem.
Most of what I've described thus far have been clunks and rattles...not really scraping. Can you further clarify your problem?
Area of the car, etc?
Limequat
Driving slow, parking on flat spots.
Old Mar 15, 2002 | 09:43 AM
CWEET CL's Avatar
HITTIN' DA SWITCHES DAILY
is the car lowered and have a camber kit?? sometimes the A arm will rub the inside fender .
Old Mar 15, 2002 | 10:20 AM
sonny_k9's Avatar
my 5sp will make that noise sometimes when I go over a bump and try to pull it in 2nd. Low screeching noise, could you be having the same problem (shouldn't say problem coz I am not sure if it is one)
Old Mar 15, 2002 | 03:13 PM
7th Gear
Limequat
it sounds like it's coming from the wheel. but it's hard to tell exactly. i will check underneath the car today to see if the exhaust is loose, but i doubt that. do u think it can be the brakes rubbing the rotors? that's what it really sounds like. but my brake lights never appeared.
Old Mar 15, 2002 | 03:14 PM
7th Gear
my car isn't lowered still stock suspension for now.
Old Mar 15, 2002 | 03:25 PM
Acurate's Avatar
K-State Wildcat
I am 90% sure this is the problem...
Our cars are equiped with a wear indicater on the brakes that makes that scraching/metal sound when the brake pads are wearing thin. This noise will get increasingly more annoying and constant until you change the pads. This is a good thing so that we don't mess up the rotors by waiting too long to replace the pads. Good idea really, annoy people enough so that they don't mess up their car. Acura is smart.
Check that out, my bet is the pads.
Old Mar 15, 2002 | 03:29 PM
7th Gear
the pads looks a bit worn. but shouldn't brake indicator come on to warn u?
Old Mar 15, 2002 | 03:53 PM
Bdog's Avatar
Not Registered
That would be a good idea to check, but the originally question was screeching only going over a bump when car was bouncing. That has nothing to do with the brake pads or discs. If the indicator was activated it would have a loud grind all the time, except when you brake it gets silent and when you hear it you would have your car checked out that day. The loudest most annoying sound to hear on a car. Could be tie rod, boot seal, loose sway bar. Is it from the front or rear of the car? Because of it only doing it when the car bounces sounds suspension related. IMO
Old Mar 15, 2002 | 09:37 PM
Ricka220's Avatar
Not Fast But Built 2 Last
Noise
My Accord with a very similar suspension had two broken springs on the front due to driving over rough railroad tracks many times. The breakage was hard to notice without running your finger around the coils near the bottom tapered coil. Check that, as it allowed the coil to move in and rub on the shocks.
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
