At a glance
At a glance
So here is whats up.
143k odometer stopped
Both axels changed
Tdc sensor no signal- rewired fixed
Leak in the exhuast sounds blah
Rattle from transmission 15-40 mph
Slips like crazy when cold.
Every bump is noticed
Vtec oil pressure switch broken and swapped.
Random brake lamp light comes on
Random stalling upon starting
Rev at 3k for a min and it stays on.
New hood x2 new windshield lol
Back rotors and brakes
Ps seems to dissapear every two weeks.
New radiator
Shop added lucas and some ford atf due to leak when changing radiator
Cleaned shift solenoid filter
New side mirror
What is a man to do when he just loves the way the car feels.
Is she savable
1998 CL v6
Nyc roads ouchhhh
Both axels changed
New radiator
New side mirror
Is she savable
1998 CL v6
Nyc roads ouchhhh
Im sure she is, What is wrong exactly? you listed a bunch of things you fixed??? Sounds like you need to do some tinkering or take it to a shop if you cant fix the idle. Id start by reading the codes, most likely with your issues it should be throwing some kind of codes... Depends how much more money and time you are planning on putting into it, usually i weigh the money i put into a car and how much i can sell it for, or if i plan on running it into the ground, but im a mechanic so i can fix anything so my cars will never die.
I've spent so much time and $ getting mine the way it should be that I lost count. You're going to have to weigh your love of the car vs the time and $ it's gonna take to get her right. I'm happy I stuck it out with mine for sure. I get a lot of compliments on mine, people can't believe it's a 1999 model. But it didn't happen overnight. Good luck!!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If it slips like crazy when cold then it's a trans issue, if it's stalling randomly then that's your TPS (throttle position sensor)
I've sunk well over 20K into my car getting it to be where I want it, that's the main reason I've held onto it for 12 years
gavriil
03-15-2005 06:14 AM
