General Info
Old May 20, 2010 | 09:34 AM
saiko_cl_duck's Avatar
General Info
Thanks to the batmobile for the link/info
Engine Type
3.0-liter, 24-valve SOHC w/VTEC V-6 (3.0CL)
2.3-liter, 16-valve SOHC w/VTEC inline 4-cylinder (2.3CL)
Horsepower, SAE net
200 hp @ 5000 rpm (3.0CL)
150 hp @ 5700 rpm (2.3CL)
Torque, SAE net
195 lbs-ft @ 4800 rpm (3.0CL)
152 lbs-ft @ 4800 rpm (2.3CL)
Redline
6300 rpm
Fuel Cutoff
6600 rpm (3.0CL)
6500 rpm (2.3CL)
Bore & Stroke
3.39 in x 3.39 in
(86.0 mm x 86.0 mm) (3.0CL)
3.39 in x 3.82 in
(86.0 mm x 97.0 mm) (2.3CL)
Displacement
182.9 cu in (2997 cc) (3.0CL)
137.5 cu in (2254 cc) (2.3CL)
Compression Ratio
9.4:1 (3.0CL) 9.3:1 (2.3CL)
Induction System
Multi-point Programmed Fuel Injection (PGM-FI)
Valvetrain
SOHC 24-valve w/Variable Valve Timing and Lift Electronic Control (VTEC) system (3.0CL)
SOHC 16-valve w/Variable Valve Timing and Lift Electronic Control (VTEC) system (2.3CL)
Engine Block
Aluminum alloy
Cylinder Head
Aluminum alloy with 4 valves per cylinder and VTEC
Emission Control
3-way catalyst
Ignition System
Full Electronic ignition
Alternator
12V, 100A (3.0CL)
12V, 80A (2.3CL)
Battery
12V, 72A (3.0CL)
12V, 52A (2.3CL)
Recommended Fuel
Unleaded regular
Body Type
Unit body
Front Suspension
Independent double-wishbone
Rear Suspension
Shock Absorbers
NWS-type (New Wide Setting)
Stabilizer Bars
(3.0CL) Front Diameter 25 mm (0.98 in) (solid)
Rear Diameter 16 mm (0.63 in) (solid)
(2.3CL) Front Diameter 27.2 mm (1.07 in) (hollow)
Steering Type
Rotary-valve, variable-assist, power rack-and-pinion
Steering Ratio
17.4:1
Steering Wheel Turns, lock-to-lock
3.0
Turning Diameter
39.04 ft (11.9 m)
Wheels
6 JJ x 16 7-spoke (3.0CL)
6 JJ x 16 5-spoke (2.3CL)
Tires
P205/55 R16 Michelin MXV4
Braking System
Front Discs
(3.0CL) Ventilated, 11.1 in (282 mm) diameter, 1.0 in (25 mm) rotor thickness
(2.3CL) Ventilated, 10.2 in (260 mm) diameter, 0.9 in (23 mm) rotor thickness
Rear Discs
(3.0CL) Solid, 10.2 in (260 mm) diameter, 0.39 in (10 mm) rotor thickness
(2.3CL) Solid, 10.2 in (260 mm) diameter, 0.4 in (10 mm) rotor thickness
Total Swept Area
(3.0CL)370.1 sq in (2389 cm2)
(2.3CL)363.9 sq in (2267 cm2)
Parking Brake
Separate parking caliper
Anti-lock Braking System (ABS)
Acura-designed system with four wheel-speed sensors and electronic/hydraulic control unit
POWERTRAIN
Type
Transverse front engine/front-wheel drive
Transmission
Ratios (:1)
3.0CL 4-speed automatic
1st 2nd 3rd 4th Reverse Final
2.534 1.502 0.947 0.608 1.846 4.200
2.3CL 5-speed manual
1st 2nd 3rd 4th 5th Reverse Final
3.285 1.807 1.193 0.903 0.685 3.000 4.062
2.3CL 4-speed automatic
2.528 1.427 0.981 0.620 1.863 4.466
CAPACITIES
Crankcase
4.6 U.S. quarts (4.4 liters) refill capacity, including filter (3.0CL)
4.5 U.S. quarts (4.3 liters) refill capacity, including filter (2.3CL)
Cooling System
9.3 U.S. quarts (8.8 liters)(3.0CL)
7.3 U.S. quarts (6.9 l liters)(2.3CL w/ 5-speed manual)
7.2 U.S. quarts (6.8 liters) (2.3CL w/ 4-speed automatic)
Fuel Tank
17.2 U.S. gallons (65 liters)
Passenger Volume
84.7 cu ft
Cargo Volume (trunk)
12.0 cu ft
Total Volume
96.7 cu ft
FUEL ECONOMY
Factory Estimated Fuel Mileage, City/Highway
3.0CL 20 / 28
2.3CL 25 / 31 (manual) 23 / 29 (automatic)
EXTERIOR DIMENSIONS
Wheelbase 106.9 in (2715 mm)
Track, front 59.6 in (1515mm)
Track, rear 59.1 in (1500 mm)
Overall length 190.0 in (4827 mm)
Overall width 70.1 in (1780 mm)
Height* 54.7 in (1390 mm)
* measured at the Manufacturers Design Load Weight
Minimum Ground Clearance* 4.33 in (110 mm)
Curb Weight
3.0CL automatic 3215 lbs(1464 kg)
2.3CLmanual 3062 lbs(1390 kg)
2.3CLautomatic 3004 lbs(1365 kg)
Weight Distribution (% F/R)
3.0CL 64/36
2.3CL 63/37
INTERIOR DIMENSIONS
Front
Head Room 37.4 in (951 mm)
Leg Room 42.9 in (1090 mm)
Hip Room 51.6 in (1310 mm)
Shoulder Room 54.4 in (1383 mm)
Rear
Head Room 35.9 in (913 mm)
Leg Room 31.0 in (788 mm)
Hip Room 47.6 in (1210 mm)
Shoulder Room 53.1 in (1349 mm)
WARRANTIES
Vehicle
4-year/50,000-mile limited warranty
Outer Body Rust-Through
5-year/unlimited-mile limited warranty
Roadside Assistance (TLC)
4-year/50,000-miles
TypeS860
Jan 10, 2026 11:11 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rcs86
Aug 2, 2016 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
