Gas Mileage
sell you car, buy a civic if you want milage
some things more pratical to consider are:
fresh oil change; new ail filter, spark plugs, wire, distributor cap; seafoam; tires inflated to 32 psi, alingment
yea, I have a 97 3.0 and I am getting 250 Miles on 1 full tank. There is no way that is normal. I should be doing at least 350. I'm going to replace the Oxygen sensor, air filter, spark plugs and wires, and test again see if that helps. Then seafoam it if necessary.
first Sea Foam and then replace all the stuff that you mentioned.....any thing that is remotely related to the air fuel mixing process should be maintained/replaced/cleaned....
Inflate the tire to the correct pressure all round...32psi as dcrop said...
Also while driving leave the lead foot at home if you want any kind of decent MPG.....
I DD 105miles on my 98 2.3cl engine with over 200kmiles on it i average 26MPG mixed driving....consedering that it is a 10yr old engine with the milage and no monthly payments......... it is a steal
my 2%
JFK
my 2%
JFK
go get your cooling system flushed professionally, new plugs, distributor cap, wires, oil, oil filter, fuel filter, 32 psi on the tires - get them balanced and aligned and you might get to where i am.
up to almost 40mpg in my 2.2. if youre as broke as me you learn to use neutral on pretty much every hill.
wow. getting 27MPG in your 2.2/2.3's
I just figured mine out int he Protege today and Im getting 21 MPG....90% city driving other than the 5 minutes every morning im on the highway to school every morning
and my engine is a 2.0 A/T
98 3.0CL Auto
13.7 gallons
278 miles (City)
20.29 mpg
Lube, Oil and Filter service around 3000 miles ($43.12 at Acura dealer)
Thinking about hypermiling but not sure putting "neutral" gear while driving on auto transmission
13.7 gallons
278 miles (City)
20.29 mpg
I've personally hit 2x 324miles w/ 13gallonss, not bad ehh? Seem better than some of the guys here =x. Less than quarter tank was highway; rest was deliveries/local. I remember it was like 25-27mpg (no calc near me, too lazy) , however pretty good for city driving/speeding here and there.
mileage
I typically get 28-32 highway. My speedo is off considerably, so it turns out I was driving 55-65 instead of 60-70+, so now I get 28-30 as opposed to 32s that I got in prevous times. I tend to gun it in the city and get anywhere from 15-20.
If you drive near the speed limit as I do on the highway ( without much variance in speed ), you'll get decent mileage with a 3.0, I think.
