fuel regulators
You dont NEED a fuel pressure regulator, and you dont NEED a fuel pump. But, either or could help you out in the long run. If you get the fuel pressure regulator, you could adjust your fuel to your own setting, if you go with the fuel pump, you could push more fuel than the stock one could where you might need it the most. They both could help you out, just as long as you get it tuned to your specs at a shop.
it depends on how big the shot it is recommended that you get a new fuel filter and look into a new fuel pump but that is only if you are going more than a 100 shot
what shot are you planning on running, what brand and what kind (ie. dry or wet)?
Zex is the way to go for most applications and it is the saest by far most other ones you have to use a push button you can run the risk of overheating the engine and possible extreme damge to the pistons and seals
pshhh.. why not just get a wet kit? Zex has an awesome K&N filter thing for a CAI or short ram that has a plug on the end for the nozzel. Apparently it makes higher HP gains than just drilling a hole in teh stock intake.
thats cause the intake that Zex makes that your talking about sprays into the filter and goes in the intake and when you gas it it makes the NOS into a vortex sort of like the tornado thingy but not exactly
but i would get the filter like ghost is talking about and also invest in the fuel pump as well, listen to dcsquirm cause he's knows
fuel filter replacement is also a good idea too
Originally Posted by jermz123
running only a dry kit 75 shot. ill take pics of the kit once its installed and my car. i finally got a digicam
with a zex dry 75 shot YOU DON'T NEED A FUEL PUMP OR FPR
anything above a 75 shot YOU WILL NEED FUEL PUMP, BIGGER INJECTORS AND FPR......
A regular K&N filter would be like $50 brand new, so you figure it's basically a K&N filter with the end replaced with a nozzle for the N20, and I'm pretty sure it comes with the N20/fuel line for the filter also, so filter($50) + nozzle attachement($5) +3' line($10) + stupid increase for the zex brand name ($10)= $75
joflewbyu2
08-18-2019 10:38 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
09-28-2015 06:51 PM
