fromt engine mount
Old Jan 27, 2008 | 01:18 AM
gnort101's Avatar
fromt engine mount
replaced the front engine mount today and added prothane inserts but broke one of the bolts to the engine, is it gonna be ok with 2 bolts for now. im gonna try to see if some shop can fix the broken one. btw, do they have inserts for the rear mounts? i(some shop) will replace the front sway bar bushings maybe next week when the parts arrive.
Old Jan 27, 2008 | 12:02 PM
Blenz's Avatar
It'll be fine with just two bolts until you get it fixed. And yes they do make inserts for the rear mounts
Old Jan 27, 2008 | 03:04 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
and
Old Mar 2, 2008 | 07:34 PM
gnort101's Avatar
finally got the bolt fixed on the front engine mount, wasnt able to get a pic but here are some pics of other install.
a lot more vibration now tho with the engine mount insert; just a couple of best upgrade recommended for suspension are front endlinks and rear sway bar.
Old Mar 2, 2008 | 07:48 PM
732xghost's Avatar
are those tanabe sways??
what kind of tie bar is that.
Old Mar 2, 2008 | 07:57 PM
SupraManAG's Avatar
One custom CL
i got those and will be installing soon. were they hard to install? you have to destroy your old ones right?
Old Mar 2, 2008 | 08:03 PM
gnort101's Avatar
that was tanabe, the tie bar didnt feel anything at all when i had that installed as well as for the upper rear. i suggest upgrade the rear sway. the mount insert and rear sway were straightforward, easy install. the bushings, had them done at the shop since i broke one of the bolts on the mount insert and had them fix it.
Old Mar 2, 2008 | 08:21 PM
G22_Powered_YA1's Avatar
I felt a bit more tail happiness when I strapped on the rear upper bar, but now I just have the front and a 100lb woofer box on the rear axle...... looking at geting a rear lower tie bar though.... sways can come later
Old Mar 2, 2008 | 08:22 PM
(Mid-Atlantic)
Gotta love polyruethayne
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
