Freakin 1361 code.
Old Nov 21, 2006 | 01:32 PM
Jordus's Avatar
Freakin 1361 code.
After some searching, i found the P1361 is the intermittent loss of signal from TDC Sensor. Problem is, this sensor was replaced ~a year ago, and i got signals 1361 AND 1362 before it was replaced (1362 is no signal whatsoever from TDC Sensor)
Now the 1361 is back, but not 1362. Couple questions.
1. Where is this sensor located, exactly, on the 2.3 VTEC?
2. What ELSE could this be other than the sensor itself being bad (short in its connectors, or possibly the dist/module/coil making this code throw out from a misfire?)
3. Any suggestions on fixing this without buying the 300$ sensor to just take stabs at it.
Old Nov 21, 2006 | 10:31 PM
Nakamichi's Avatar
~[τΏτ]~
Around timing belt cover. #15
-Open in the CKP/TDC sensor
-Short in the CKP/TDC sensor
-Open in wires from ECM/PCM to sensor
-Short in wires from ECM/PCM to sensor
-Faulty ECM/PCM
1. Unplug the sensor connector, On sensor side check the resistance between top two terminals, then bottom two. Both should be between 1850 to 2450 Ohm. If not replace sensor. Otherwise, goto next step.
2. On sensor side, Check continuity between each terminal to body ground. If found, replace sensor. Otherwise, goto next step.
3. Check for resistance between ECM/PCM terminals 8 &9, then 20 & 21. Both should be between 1850 to 2450 Ohm. If not, repair open. Otherwise, goto next step.
4. Check continuity between ECMPCM terminal 8 and/or 20 individually to body ground. If found, repair short. Otherwise, goto next step.
5. Substitute for known-good ECM/PCM.
saberlove
Mar 11, 2021 09:29 AM
Tim Giron
Mar 18, 2016 09:50 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Tommiepickles24
Sep 10, 2015 12:30 PM
