foggy headlight
DamnThisHobby'sExpensive!
i think the factory rubber seal on my drivers side headlight broke cuz when i wash my car...its get water inside, well its just like foggy, not flooded...i donno how but it goes away usaully by overnight...althought my garage is hot as a mo fo so that helps
Trailblazer = SUCK
f u have aftermarket bulbs or changed the stock ones recently, check to see if you made a tight seal putting the bulb back in. if there is any outside air getting into the sealed part of the housing it will fog up when you get it wet.
AmplifiedDetails
09-24-2015 02:55 PM
