Fog Lights
OrIgiNal GanGstA
yes i have some. the kits come with all the wires brackets and screws I WOULD GO AHEAD AND BUY MORE WIRE MOST KITS DONT GIVE U ENOUGH WIRE all u do is mount the brackets were u want the lights to be run a positive and negative wires from the lights to the battery and then ground it to a screw on ur car were metal touches metal hide the wires and then hook it to the toggle switch
A-CL Post Whore w/N2O
All 1st Gen CLs are pre-wired for the factory fog light kit. If you're looking to install the factory foglights, here's the instructions: http://public.fotki.com/dustbuster4/installingwiring/ [After selecting a pic, click on "Get Original Uploaded Photo" for large size pics.]
If you're looking to buy them, this guy is legit: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2423524203
hey guyz.. im bringing back a dead post here.. haha..
im getting PIAA foglights.. but im not sure if they come with wires and everything..
do they usually come with a switch and wires?
and also.. if they dont come with the switch.. where would i buy it?
I'm a llama :(
If I were to buy aftermarket fog lights, I'd wire it up to the factory harness using the factory switch. You just need a relay. Then I'd cut the "hot" wire that goes to the button and wire up another "hot" wire that's hot with the ignition. But that's just me...
...is now Carbon Fiber'd
hey post up a pic of the fog light you are using...or what model...want to know what you are using...thanks
I'm a llama :(
Originally Posted by chuckz
where is the switch located.............i don't have stock fog lights and i havn't seen a switch yet.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33709
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
i dunno.. still up in the air
I'm a llama :(
Originally Posted by sumdumguy
are all first gen already wired? so all I'd need would be fogs and a switch?
BUT!!! I just took off my bumper and I don't see ANY wiring for the fog lights. Someone posted a picture a while back with the wires and a blue connector. I don't have squat.
I'm a llama :(
can someone show me where the plug with blue tape is?
i have no idea where it is..
so basically.. 1.)i have to connect the foglights to the battery (positive, negative cables) 2.)then ground it somewhere.. 3.)then i have to find the plug for the switch inside my car where i have to 4.)solder the piaa wires..
5.)install the switch.. and it should work?
thanx for the responses guyz!
Originally Posted by azn5ucka86
i found mines where the radiator is, the foglights connect into a female connection around that area in the front grill area
thanx guys! ill post pics once i get them installed!
I'm a llama :(
1. First hook up the switch.
2. Then hook up the 85 pin on the relay to a ground (any metal on the car).
3. Hook up the 86 pin to the battery.
4. Find the "hot" wire coming from the foglight connector.
5. Then hook that up to the 30 pin.
6. Then hook up the 87 pin to the foglights.
7. Ground the foglights.
I believe this is how it goes. I hope I'm not wrong. If I am I know someone will correct me .
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
