Fog Light Question
Fog Light Question
Sup fellas,
I just picked up a 99 CL. I'm interested in adding fogs. I'm probably going to pick up these fog lights: http://www.eliteone.com/catz/xsl.htm
How do you think they'll look?
Is there a DIY guide on wiring fog lights?
Is there a place to mount them?
I've been looking around for an acura CL fog light switch and can't find one. Can i use one from a different car? If so, which cars?
Here's a pic of my CL.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You can use the fog switch from a 94-97 accord, the fog light kit should come with all the wiring you need
Cool, thanks.
Will any other buttons work? I'm thinking about wiring them to go on with the headlights if that's possible.
Is there a guide on installing fog lights floating around somewhere?
i have done non oem as well as oem fog lights. non oem foggys always come w/ directions there simple tho you have to run a line to the battery. and you have to have a ground it should also come w/ a switch
the fogs should be already partially prewired. I can confirm that I plugged in my fog light switch(right behind the knock out switch opposite the hazards) in when I was installing my head unit and the switch does indeed light up. The wiring should go from the interior to the firewall. with the aftermarket wire harness you could prob wire it up to there. I'm still trying to figure out my plans, i hate wiring
N00berator
ur CL looks good from here...nice prelude as well...good luck with fogs...IMO davezilla did an awesome job with his...first it looks weird but u get used to it...
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
