Finally Finished Installing Suspension!!!!
Old May 14, 2007 | 07:35 PM
$peed])emon's Avatar
Si says "shut the fuk up"
Before i show you the pics i must tell you my story....I had no prior experience in installing suspension or removing/installing bushings. I was in for a huge surprise....
First i installed the fronts no problems. Then i got to the rears. I got the strut out by cutting the bolt that snapped off at the bottom. That was the least of my problems....i then realized that the bolt was so stuck into the bushings that i tried to drill them out...didnt work. i had to end up buying new bushings....
I had NO idea how hard it was going to be removing those bushings, but i was so persistent....so after torching, sawing and hammering and finally pressing on the new bushings, i finally was able to put the rear suspension on.
SO after about 4 days of panic, my KYB AGX/ Neuspeed sports are in.
Im out to enjoy my suspension now and pics will be up tonite!!!
Old May 14, 2007 | 07:38 PM
CLpwner's Avatar
Mmmm...
Nice... are you gonna add to the suspeinsion DIY... any things it left out... Please do
And i cant wait for the pics...
Old May 14, 2007 | 09:11 PM
HERE ARE SOME PICS!!!
This is what i ran into. Bushing was done:
These are the 2 bolts i had to buy:
These are the 2 bushings i had to buy (rawbeans told me these couldnt be purchased before..) :
This is what i did to get the old bushings out:
Left side bushing:
Right side bushing:
Both bushings:
I Had to burn out the old bushings and then cut and bang out the outer metal ring
I did not take pics of how to press in the new bushings because my hands were really dirty and didnt want to mess up my phone. I used a 27mm socket, bench vise, and some pieces of wood to press in the new bushings into the knuckle. This process was VERYYY VERYY HARDD...
Here are the finsihed results:
2 finger gap in the front:
2 finger gap in the rear:
And full body shots:
This adventure has taught me soooo much....i can now proudly say "I can replace bushings and suspension on my car. FUCK YOU SHADY MECHANICS!!" HAHAH
SEE YAAA!!!
Old May 14, 2007 | 09:20 PM
CLpwner's Avatar
Mmmm...
Nice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 14, 2007 | 09:23 PM
ZeroCL's Avatar
W WHIP.
Good looking drop!
Old May 14, 2007 | 10:14 PM
herbalist's Avatar
chips and smokes, lets go
looks good. looking forward to seeing the finished product with the new wheels. unfortunately, i can see there is rust-a-brewin' in the infamous quarter pannels. i've got the same.
Old May 14, 2007 | 10:19 PM
chinoscl's Avatar
looks good im thinkin about doin it myself also. so how many new bushings did you need in the end
Old May 14, 2007 | 10:29 PM
Yea, rust is a real bitch. i hate it so much. my next mod will be to fix all the rust on my car
if you read my post chino, then you would see that i had to buy 2 bushings and 2 bolts.
Old May 14, 2007 | 10:51 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
how da fuk do u 'press' something in? because i can press really hard and not get anywhere..
Old May 14, 2007 | 10:55 PM
herbalist's Avatar
tell me about it. i wonder if these would work for our cars.
http://cgi.ebay.com/ebaymotors/Honda...em120117401147
Old May 14, 2007 | 11:18 PM
i used a bench vise to press the stuff in. i also used a 27mm socket on one side and some pieces of wood on the other side because the bushing sticks out a bit.
i hope you werent trying to press stuff in with your hands LOL...
Old May 14, 2007 | 11:19 PM
Im pretty sure those would work. they have the general shape for our cars and you can just trim whatevery you dont need off with tin snips.
Old May 15, 2007 | 12:05 AM
Cocoa's Avatar
2600lb CL
You can buy the presser for about $200-$300 at autozone, depending on how much compression you want.
Old May 15, 2007 | 12:41 AM
Dez97CandyCL's Avatar
...nO phOtOshOp...
yea... i used my friend's bearing press 2 replace sum worn out bushings... beats buyin 1....
you can find em online for cheap....
Old May 15, 2007 | 08:42 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old May 15, 2007 | 01:05 PM
hmmm.. i rather not pay 200-300 USD(300-400 CAD) for something that can be done with normal tools.
Old May 15, 2007 | 01:09 PM
Cocoa's Avatar
2600lb CL
It's more for puliing and pressing in wheel bearings and such. Bushings can def be done with normal tools like you said, but at a much slower rate depending on where it goes.
Old May 15, 2007 | 01:10 PM
Cocoa's Avatar
2600lb CL
It's still relatively cheap.
Old May 15, 2007 | 01:17 PM
kinda....i think 400 is alot for a tool that i would hardly use....
Old May 15, 2007 | 01:43 PM
...nO phOtOshOp...
here ya go....
1 ton press....>$39.99 + s/h
http://www.northerntool.com/webapp/w...70_35090_35090
Old May 15, 2007 | 02:20 PM
Originally Posted by Dez97CandyCL
here ya go....
thats a good price.....but you would have to take off the knuckle (pita) to use that. i didnt have to remove anything when pressing in my bushings with a bench vise....
Old May 15, 2007 | 02:23 PM
plus, you need other tools with that 1 ton press like dyes and stuff because there is no holes in the base of the press....still a good price tho...i wonder if 1 ton is enough power to press stuff on....
Old May 15, 2007 | 03:33 PM
...nO phOtOshOp...
true...either way you cant beat that price... and i dont see why 1 ton wouldnt be enough compression power....
Old May 15, 2007 | 04:10 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
so a press is a glorified c-clamp. maybe i can rent one from autozone..
i need to change the bearing from my halfshaft to the driveshaft..
Old May 15, 2007 | 05:42 PM
Dicorp's Avatar
right rear quater panel for me...
Old May 15, 2007 | 06:08 PM
...nO phOtOshOp...
mines the driver's side rear... damn u would think acura's were perfect haha
Old May 15, 2007 | 06:21 PM
herbalist's Avatar
both sides for me. i have to do something about it before it gets out of control.
Old May 16, 2007 | 08:37 AM
(Mid-Atlantic)
That's not what my tranny said
Old May 16, 2007 | 10:43 AM
732xghost's Avatar
my rust totally kills the look of my car. its horrible.
nice drop though.
Old May 16, 2007 | 10:48 AM
damn...my rears are squeaking a bit...i dont think i lubed it up enough..
Old May 16, 2007 | 11:14 AM
...nO phOtOshOp...
Ahaha,
yup my shits in the on the fritz right now...
i think i have a hairline crack in my cap
Old May 16, 2007 | 11:16 AM
manual tranny > autotragic
Old May 16, 2007 | 11:37 AM
(Mid-Atlantic)
v6 > 4 banger
Old May 16, 2007 | 11:39 AM
fuel economy > wasting money
Old May 16, 2007 | 01:00 PM
...nO phOtOshOp...
ahhaha... i like the way u think
Old May 16, 2007 | 01:18 PM
732xghost's Avatar
v6 > 4 banger
still not fast.
Old May 16, 2007 | 01:21 PM
(Mid-Atlantic)
my v6 does get good gas mileage though
(Mid-Atlantic)
Originally Posted by 972xghost
still not fast.
I have never once claimed that my 3.0 was fast
Old May 16, 2007 | 03:48 PM
732xghost's Avatar
these arguements never go anywhere idk y we all still bother. lol
