Exhaust install question
Feeds pigs bacon
Ok, I'm buying the Greddy Evo II exhaust for the 94-97 Accord EX. Anyways, I'm wondering if when I go to install it if I'll get problems from the shop because it's for an Accord not a CL. Do I need to tell them that it fits my car? Or will they know this. I just don't want them to not want to install it because of ignorance.
Thanks.
Thanks.
Comrade Stalin
Thanks.
Thanks.
Feeds pigs bacon
Sure, let me whip out my lift, my tools, and technical know-how. If you have a tutorial or something I can read, I'll definitely read it though.
I'm a llama :(
I just used a jack. Air tools are VERY helpful though. It's pretty self explanetory. Just remove some bolts and hangers and put in new muffler. Too bad you don't live nearby, I'd help ya. How much is that shop charging you?
Feeds pigs bacon
Probably in the $100-150 range...but I'd really consider doing it myself just so I can know how...I mean, if I mess up, I can just take it to the shop anyways, right?
Feeds pigs bacon
Actually, I'd have to rent air tools because I live in Ohio, land of salt and the bolts are going to be on there so tight. And renting them from Autozone or something will cost as much as getting it installed, correct?
a jawful a somethin awful
NAWWWWSSSSSS
1 Post
mind as well buy one. you could get a huge tanked compressor with an air tool set for around 200$ for sure.. you will use it forever, and ever, it has soooo many purposes, change wheels in under 10 minutes, tighten or loosen anything, grind down metal, blow water out from inside of mirrors, door cracks the list goes on and on... air tools makes any job take under half as long
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
I'm a llama :(
Dont' forget to post pics
. Also, $100 is a lot just to bolt up an exhaust. If they had to cut and welt, then It would be more, but just to bolt it on, it should only be like 30 bucks.
Originally Posted by DrDre1443
any muffler shop will charge you one hour labor and do it in 20 minutes......here the midas is 65 bucks an hour.
Flap.
becareful if you remove/install lug nuts with air tools, very easy to over tourque those bolts and cause shaking or damage
Flap.
go to a speed shop where an hourly rate will be less like 50 or so and have them do it, they really cant mess it up unless they hate you
I'm a llama :(
![Jesus LOL](https://acurazine.com/forums/images/smilies/jesuslol.gif)
Thanks.
Thanks.
Feeds pigs bacon
Sorry to bring up an old thread but I finally got the Evo II installed....cost $85 (about what Randol said) because they had to do some cutting.....
HOLY FUCK this thing is mean sounding. I'll post some vids and pics if you'd like.
(2.3 5spd btw)
(2.3 5spd btw)
Tristate ViP Crew
(2.3 5spd btw)
(2.3 5spd btw)
Is it super loud? How much cutting because I want to order that one or the HKS Super Drager.
eh f**k altezzas.
Originally Posted by BlueCLRycR
you know those little irrigation ditches they have on the sides of the road to channel water away from the road? park your car like this -----[===]---l l just pull in off of a driveway and straddle it. no lift required. unless its not a bolt on then youre SOL. thats how i did mine and i had plenty of room to work comfortably. ghetto i know but hey it worked.
wow
eh f**k altezzas.
Originally Posted by Atny02
wow
johnpancakes014
04-08-2016 06:47 AM
IIDXholic
10-08-2015 07:53 AM
Hau_nguyen91
09-06-2015 12:53 PM
