Engine Rough
Old Oct 7, 2005 | 04:52 PM
mdashali's Avatar
Unhappy Engine Rough
Hey,
My 97 2.2CL engine seem to be getting rough in the past couple of days. I also noticed that the idle rpm is a bit higher than normal. Last month I switched to Mobil 1 synthetic and a friend told me that I will have to change oil initially after 1500 miles. I just drove 1000 miles and I checked the oil yesterday and it was somewhat dark and thick. So got an oil change yesterday thinking that it will fix the problem. But nope. I am not sure what else could be the problem. All I could see is my poor CL is trying hard to push itself through the traffic. Could there be any lubrication problem or my engine is dying? It has got only 85k on it and I got its timing belt changed at 80K.
Please share your wisdom.
Thanks!
Old Oct 7, 2005 | 05:28 PM
legendaryCL98's Avatar
'07 November = STI
is your car over heating?
stick or auto?
switching to synthetic shouldnt be a dramatic difference as u explain it.. something else should be wrong..
unless! synthetic is actually bringing out the raw NA power from your engine.. haha
eh.. im just joking..
Old Oct 7, 2005 | 05:37 PM
mdashali's Avatar
No it is not overheating.
It is just a bit more in idle rpm and some notable roughness and engine noise.
It is a 5spd.
Old Oct 7, 2005 | 05:41 PM
'07 November = STI
who fixed your belt? dealer?
Old Oct 7, 2005 | 05:42 PM
mdashali's Avatar
A local mechanic. He is very experience though
Could be a belt related problem?
Old Oct 7, 2005 | 05:46 PM
'07 November = STI
it might be.. u might wanna call him up and ask him..
doesnt sound healthy
its been only 5K miles since the service right? so it might be related to it
Old Oct 7, 2005 | 08:49 PM
ajtcl's Avatar
Peace, Love & Acura
If your TB was the problem, your shit wouldn't be running. Is your CEL coming on? You could have a failing IMAP or IAC sensor issue. If you just had it serviced, check and make sure you do not have a disconnected sensor or a vacume line that has come loose or been left unattatched. Now if the engine is weeerrrrriiinng when it is idling, it could be that the TB is touching the cover, but I highly doubt that is the case.
Good luck bro.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
gator90065
Oct 8, 2015 10:14 AM
Frathora
Sep 28, 2015 11:29 PM
IlliniAcura
Sep 19, 2015 09:31 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
