Engine Parts/Info
Engine Parts/Info
Misc Engine Parts.
All 2.2/2.3 engine parts come from a 94-97 Accord (F22) or a 98-2002 Accord (F23).
All 3.0 engine parts come from a 98-2002 Accord V6 (J30A1).
Acura 3.2 CL-S/ TL-S cams can be put into a J30 block.
Interchangeable parts
92-01 H22 rod - > F22a/b rod (will push stock F piston out of the hole)
H-series is interchangeable with F-series notes
Block:
98-01 H22 crank -> F23ax crank (will destroke 7mm, use H rods?)
92-97 H22 crank -> F22a/b crank (will destroke 4.5mm)
92-96 H23 crank -> F22a/b crank (same part)
92-96 H23 rod -> F22a/b rod (same part) F22a/b rod (sam
Block:
yung.nate1st.gen.cl (10-18-2015)
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
2002, 23, 30, 32, 98, accord, acura, cl, f22a, f23, interchangability, interchangable, interchangeable, interchangeble, j30, j30a1, parts
