Electrical Problem
Old Jan 10, 2006 | 10:26 AM
yossi's Avatar
Electrical Problem
1997 cl 3.0 112,000
Last week, i went to start my car, i turned the key to the first position, the indicator lights went on, then everything went completely dead, no power. i took the key out, then back in and the car started, however everything had reset, the clock, radio, etc, as if the battery had been out.
Last night, i was driving, i have a converter plugged in my cig plug for my laptop. The laptop suddenly indicated that it was on battery power. the little green indicator on the converter was on, indicating it was getting some power from the cig adapter, however it wasnt puttig out any power to the laptop plug
Finally, after that started, everything started flickering, headlights, dome lights, and all dash lights.
My battery and alternator are about 3 months old, and i continued to drive the car for another 300 miles last night, battery still at full power, however all problems still exist.. any ideas?
Old Jan 10, 2006 | 10:36 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Are your terminals clean?
Old Jan 10, 2006 | 10:42 AM
yossi's Avatar
yea, clean, tight,
Old Jan 10, 2006 | 12:13 PM
SwervinCL's Avatar
Nom Nom Nom Nom
hmmm... what about your connections to your altenator?
Old Jan 10, 2006 | 12:14 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Get a voltmeter and see what your battery reads at. Otherwise, it's an alternator output problem.
Old Jan 10, 2006 | 04:21 PM
yossi's Avatar
ok, ill test that, I hope it is the alternator, since it was just changed 3 months ago, so hopefully still under warranty
Old Jan 15, 2006 | 11:09 AM
yossi's Avatar
when i tested, everything seems ok, problem is, i usualy only see the flicker when going at highway speeds
Old Jan 15, 2006 | 12:24 PM
Sumaccordguy1994's Avatar
loose connection somewhere... probably at the fuse box under the hood... or the main fuse is loose...
Old Feb 8, 2006 | 02:26 PM
yossi's Avatar
Checked all my connections. Yesterday the problem worsened.....
I was driving, suddenly the radio lost power, the ABS light came on, car still driving, with a wierd tick-click noise coming from the passenger airbag area. I pulled over, turned the car off, tried to restart it, car was totally dead no power at all, no clicking or anything, i left the key in the start position, after 30 seconds all power came back on.. I have a small tester, it says battery and alternator are both ok,, any ideas?
Old Feb 8, 2006 | 02:43 PM
SwervinCL's Avatar
Nom Nom Nom Nom
I would actually take your altenator out and get it tested. It may not be bad, just on its way.
Old Feb 8, 2006 | 03:12 PM
(Mid-Atlantic)
Old Feb 8, 2006 | 04:20 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
He said the alternator is almost new. Same thing happened to me, and i excersized my alternator warranty, and now its fine.. When the crazyness happens do u smell anything funny? Or feel your alternator a lot hotter than usual?
Old Feb 8, 2006 | 04:24 PM
yossi's Avatar
took it to strauss they ran a charging system test, said it came up fine, at higher speeds, all the dash/head lights flicker, which makes me think its the alt, however it dosent do it at low speeds, so im not sure how to reproduce the problem when the car is sitting in the shop
Old Feb 8, 2006 | 05:49 PM
SwervinCL's Avatar
Nom Nom Nom Nom
I would put 100 bucks on your altenator. Buy a new one and throw it in there and try it. If it works then you win. if thats not it, then take it back.
Old Feb 8, 2006 | 07:38 PM
yossi's Avatar
unfortunately i lack the skills/ability to replace the alternator on my own.
Old Feb 8, 2006 | 08:16 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Someone with a 3.0 help this guy. I know on mine its very easy. Its only like 2 bolts. It will save yourself some money. TRUST ME!
Old Feb 8, 2006 | 09:44 PM
Mulk's Avatar
The new ride
search, the instructions are on AZ somewhere cause i found them when i did mine last summer
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
