EGR valve cleaning
EGR valve cleaning
so i just bought my EGR valve and they told me tha before installing it i need to clean the carbon outta the engine, i dont want to give my mechanic 50 to installl this since its a goddamn easy job. what do i need to clean it with??
egr valve port cleanin
hey hey you are in luck. i just did a complete egr valve port cleaning. what you will need to do is remove your fuel rail. right underneath it there is a cap that spreads over the intake manifold. remove the 5 10mm bolts, pull up cap, get some car cleaner or some intake cleaner and start spraying. you will notice a little hole in each of the legs of the manifold; make sure you clean them well. after that is complete get you a can of seafoam and run it through the PVC valve and watch your car smoke and clean all the carbon out
