Is this the ECU I need for my swap?
Old 02-22-2005 | 09:33 PM
thirdrail-1's Avatar
H22 Black Ack
P13 ECU
Is this what I need for an H22a swap into a 99CL.
I am most likely going to buy a 97 motor because they are easier to find. Will this ECU give me any problems?
Old 02-22-2005 | 09:38 PM
baka_t's Avatar
The movement has started
Yup, that will work. Don't forget to get the obdII to obdI jumper harness.
Old 02-22-2005 | 10:03 PM
H22 Black Ack
And will that be all I need? Will the engine come with the wiring harness up to the OBD! to OBDII Jumper? What part of the stock harness will I be able to use, or will I use any of it?
TIA.
Old 02-22-2005 | 11:24 PM
baka_t's Avatar
You can use all of it, all you need is the jumper harness, only if you are auto, and going to manual, then will you have extra sensors left over.
TypeS860
09-03-2021 06:42 PM
Skirmich
10-01-2015 12:59 PM
malvothegreat
09-29-2015 12:38 AM
xsilverhawkx
09-28-2015 06:51 PM
hpfiend
09-27-2015 06:59 AM
Quick Reply: Is this the ECU I need for my swap?
