dash lights flickering and sunroof probs
Old 05-20-2008 | 06:00 PM
SpAzZy's Avatar
Have any of you experienced any problems with your dash lights? When i turn my headlights on my dash doesn't light up anymore. Every light dies instantly when I turn on my low-beams. Used to be an easy fix, a quick smack on the top of the dash would turn them all back on. Now its just dark forever. Its not the bulbs, maybe some loose wiring inside but weather hasn't been good for me to run a full check yet.
I drive in the dark, had the car for long enough to know approximately how fast i'm going haha. just curious to see how common this is. i tried searching but this 60 second one search function is owning me. i haven't found a similar thread in the past couple of days.
my sunroof gave out on me the same week as my passenger window regulator about a year ago. i replaced the window reg myself for $70 (ebay) but the sunroof is a different story. the motor works, just when i push the button, it goes no where. doesn't look to be off the tracks. it's forever in the closed position. it'll drop down a little bit if i press open, but thats it. and it goes back to the close position if i close it. haven't taken it to acura to have them check, its on my list of things to do though. anyone experience this?
Old 05-20-2008 | 08:49 PM
DaInFaMMuS1's Avatar
you should def check your alternator and wiring for the dash thing, sounds like something is not getting relayed or connected for power. Idk bout the sunroof thing, sounds like something may be stuck in the tracks or something
Old 05-20-2008 | 10:42 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds likea bad ground, loose fuse, or corroded bat terminals, start there
mada51589
05-03-2022 08:54 PM
Ol'Dave
09-05-2020 02:56 PM
BoricuaTL
04-08-2016 01:08 PM
Rob144
09-21-2015 08:18 AM
Greengecko
09-16-2015 08:19 PM
Quick Reply: dash lights flickering and sunroof probs
