CYP Sensor? Does the CL have one?
Does our cars have a CYP Sensor (Cylinder position)? I know that there is a TDC, CKP sensor but what about the CYP.
is it located by the timing belt, under the casing?
I know it somehow interacts with the distributor but does it go straight to the dist or does it go to it down by the cam gears , timing belt, etc.
I used my old harness and the distributor wires were different from the cl (external coil) so there was some modification there. I don't know if maybe I put the cyp sensor to the wrong thing or?
Fiill me in.
thanx bro. Howz the turboz runnning?
Fiill me in.
Swaps? $3000 for 50HP? :(
Its in the distributor. Its the brass guy on left of this pic:
The car runs like a dream. Havnt had time to put in the wideband since I'm insulating/painting the garage (prepping for the non-GA winter)
i am pretty sure i got it hooked up but the car still doesn't run.
Here is the prob. when i turn to key on and put the wire tester to the injectors and hold it there for ex: 8 sec each injector the car will run for about 3-5 seconds. WTF? It has to be something with the CYP right? You think it got fucked up when this shmuk plugged in both ecu's or maybe i still don't have it hooked up right or grounded. I gotta keep fuckin wit it.
Thanx.
Thanx.
If everything is in time and the sensor is good...you shouldnt have a problem.
Try this. Have a friend turn the car over while you move one of the plug wires from a plug. Does it act any different (are you getting spark to the plugs?)
yeah they get spark.
i already had to replace the integrated control module, i mean swap it from my 2.3.
it is all coming down to whatever controls the injectors, unless maybe they are not grounded correclty. I will figure this out today if i die trying. i passed out lastnight so -
thanx for the help.
thanx for the help.
