Cost of Transmission Rebuild?
I want to go on a road trip cross country this summer with a friend of mine, to NYC, Miami and then Monterrey Mexico (to see a friend) and I know my car would be up to it. The only thing I would be worried about is my transmission. It doesn't grind or have synchro problems, it just make a clicking noise from inside it. If I'm in a parking lot going around 15mph if I give it a little gas and then let off it'll start clicking/ metallic thunking but its a different noise then the CV joints (plus theres no vibration). Also, if I downshift into 3rd, 2nd or 1st without being really smooth it'll make the same noise.
I jacked the car up and moved my axles around and it sounds like its coming from inside the transmission, which is really weird since other then the noise, its perfectly fine. I wouldnt want to be in the middle of nowhere and have my transmission grenade or something.
btw, could it be clutch related? Because if I make sure to shift super smoothly it wont make the noise.![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
edit: I'm going to buy some stock springs or sportlines or something to put on for the trip, theres no way I'm gonna drive 6000 miles 2" off the ground
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like the tranny's starting to go, mine clicked for a while too b4 it blew. It was a problem with the bearings at the rear of the tranny breaking off and floating back and forth through the gears shredding chunks off and then the gears weren't catching all the way or something along those lines, my tranny rebuild was $2800
Fuuuck that sucks. When I go home next month I'm gonna drop the tranny and take a look. Maybe I can replace whatever's worn before it completely destroys itself
One custom CL
edit: I'm going to buy some stock springs or sportlines or something to put on for the trip, theres no way I'm gonna drive 6000 miles 2" off the ground![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
good luck through NJ/NY. j/k if u know how to drive a slammed car you'll be straight. dont waste your money switcing to different springs for a US cruise.
you'll be fine. you'll be in 5th gear 75% of the time
i have trouble putting my car into 1st and reverse and im fine.
Plus, if I had mechanical trouble there is no way they could get it on a flatbed without destroying my car. I'm just gonna grab some other springs to be safe. Plus my friend would drive too, and he doesn't know how to drive a slammed car
You think so Jay? Its loud enough to hear inside the cabin. btw, there needs to be another meetup sometime soon.
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by dragon084
I have faith in the CL.
Good/Bad?
http://cgi.ebay.com/ebaymotors/90-02...QQcmdZViewItem
What about this?
http://cgi.ebay.com/ebaymotors/EXEDY...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/ACCOR...QQcmdZViewItem
I would definitely need to replace my clutch before the trip, it doesn't slip at all but it doesn't engage until its almost out of pedal travel.
What about this?
(Mid-Atlantic)
(Mid-Atlantic)
Exedy stage 1
Good/Bad?
What about this?
What about this?
http://www.acura-cl.com/forums/showthread.php?t=179567
Damn, my '99 CL rcently started doing this also. Shifting from 1st to second i can hear a "faint knocking" from the engine...I didnt know what it was until now..Unless its a super smooth shift, it usually happens...also I have trouble getting into 1st sometimes...ill have to shift to 2nd then back to 1st, could this be a syncro problem? Im glad I bought the extended warranty for the tranny, ill have to bring it to a dealer and haev them figure it out.
4x4- fat chicks cant jump
nah were gonna have to deal with it, its something with our gear synchros.
does 1st gear for you sometimes engage ruff or half way, then u let of the clutch and it falls in place?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
My Car does the same thing in 1st...Anyone know what it is?
Originally Posted by SilverCL97
my first was always fine but every now and then it wouldn't like to go in
SinCityTLX
20
10-19-2015 11:23 AM
joflewbyu2
10-08-2015 11:16 AM
