Cocoa Dyno!
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Cocoa Dyno!
http://s87278733.onlinehome.us/main/...cocoadyno2.JPG
I'm pretty sure that's not vtec you are looking at crossing over, that's probably where he stepped on it
crossover is definately at 3500. I have a relatively stock dyno somewhere but can't find it.
Since it's an automatic it's hard to get the car to dyno at WOT and cross into vtec so most places just punch it, when he punches it it's obvious it down shifted and went into gear at 4500 my dyno looked the same but came on a little earlier
see on the stock dyno you can see it kick in at 3800 which is normal cause honda's tachs are about 300 off
1 Post
so the blue is the before run, adn the green is the after run? how do you know he didn't gun it at 3500 rpms in teh stock run, and gun it from teh beggining in the "tuned" run? This may be why it seems to ave such a drastic improvement...
1 Post
no dude, the blue is teh first run, the green is teh second run. if you actually look at the thing you'd see that. you're shit didn't increase THAT much. The ones that start aroudn 75 are teh torque curves, and teh ones that start aroudn 150 are teh HP curves.
Though for 175 bucks and increase of about 10 both HP AND torque is pretty good. better than my intake that's for sure.
2600lb CL
sorry, i never looked at the sheet...i was just hoping i knew the right colors, lol...i was too lazy to open it up again and take a look.....anywayz....175 for 11whp is pretty damn good.....and thatz 11 final whp......but as you can see, i gained hp throughout the hp range......
if you notice though, his gains are throughout the whole RPM range, that's the important part
2600lb CL
AEM CAI
Apexi N1 Exhaust w/ 2 1/2 inch piping
UR Pullies (crank, alt, ps)
OBX Headers w/ Downpipe
VAFC2 tuned, w/vtec engagement at 3800rpms
Transcooler
Bosh Platnium +4 Spark Plugs
Neuspeed springs
Stripped back (no seats, or spare tire)
Clear corners
All synthetic fluids in motor and tranny
Type S Cams soon to be installed
Hyper Ground System Wires soon to be installed
Wings West rear lip kit to be installed/molded later
Bought a second tranny now sitting in my garage
Yea, with the mods you have, it would be a good investment....
Transcooler
Neuspeed springs
Clear corners
1 Post
When does yours shift Cocoa? I got my wisdm teeth pulled a few years ago, they gave me some shitty pain killers that made me puke, so I ended up just taking Ibuprofin... then I ate popcorna dn got peices of popcorn stuck in the holes back there.. I never had any problems though, and it fully healed in about 2 weeks.
1 Post
yeah, well I'm not gonna go ask you to find out in your current state. It's kinda difficult to drive while on vicoden, depending on how much you've had before, and whether you're used to it or not. Find out some time and let me know... especially after this dyno/tune.
Oh yeah, I definitely noticed that. I'm sure that'll chop off a little bit of his 0-60 time, Currently my 3.0 shifts from 1st to 2nd at about 38 mph, I's sure after I/H/E and vafc it would probably shift around 45 or so, not exactly sure.
It doesn't mean you shift later, shift points will be the same unless you change gearing, it just means you'll get their quicker
1 Post
oh yeah, don't mind me. I just woke up and my critical thinking skills are skewed. My logic was that if the car had greater HP and torqu at the same RPMs then it owuld be moved further in the same time, but Iw as thinking of the gears in terms of like bicycle gears, where if you stopp peddling it would just rool and the peddles would stay in teh same spot, but I forgot that the car would pull the engine along, so the car would acheive equivalent RPMs at teh same speed. Yeah, I sholdn't sleep for 12 hours anymore, I feel high when I wake up.
2600lb CL
ENGAGE MY VTEC BABY!!!!!!
i have my vafc installed in my 3.0 and i have mine set to 4000
i have had it set to 3800 but no gains without a dyno and a tune then again i have the vafc1 and not the 2nd gen vafc
how much did he charge you to tune the vafc?
how much did you gain with just the vafc controller?
i like orange juice
goddamn, what areyou CLpower? God or something?
edit: you should add that quote to your sig also scott :P
D-Rob
62
01-05-2016 11:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
