Clutch Fluid?!?!?!
Old Mar 21, 2006 | 03:23 PM
732xghost's Avatar
Clutch Fluid?!?!?!
i pretty much figure out that my problem here is due to lack of clutch fluid but id figure i share this with you
i warm up my car every morning before school and went it was finally warm i leave, the only problem i know of my gears are engaging. so im like WTF!!. so then i go check my clutch fluid, and its bone dry. i cant believe i overlooked that. so when i got to work later im gonna fill it up, i can use brake fluid if i want though right.
Old Mar 21, 2006 | 07:02 PM
CL Platano's Avatar
Tristate ViP Crew
Yes you can use brake fluid, and get your master & slave cylinder checked mine were shot when I got rid of the car, I had to add fluid every other day.
Old Mar 21, 2006 | 08:22 PM
732xghost's Avatar
i gotta get the clutch master cylinder bled, and if thats not helping then im gonna get my slave master cylinder replaced. i already got 113K so i should probaly get a new anyways.
Old Mar 21, 2006 | 09:57 PM
teh CL's Avatar
bleeding that shit is a bitch..i did it acouple weeks ago when i replaced the master and its a bitch
Old Mar 21, 2006 | 10:48 PM
Sumaccordguy1994's Avatar
its much easier to bleed than the brakes... no wheels have to be removed... just have help to push and hold the pedal.
As for the resivoir being dry, that means there is a leak somewhere... hydraulic systems do not "use" any fluid. Theres a good chance its the slave cylinder, which is pretty cheap.
Old Mar 22, 2006 | 11:40 AM
732xghost's Avatar
so you dont think overtime i just ran out??
Old Mar 22, 2006 | 03:37 PM
732xghost's Avatar
me and a mechanic i work with our gonna bleed it out tonight just in case, my slave should be fine, nothing is leaking and now that i put brake fluid into it the gears are engaging fine, were just gonna bleed the master cylinder out and take a look at the slave cylinder.
Old Mar 22, 2006 | 03:39 PM
teh CL's Avatar
good stuff..your lucky u work at Honda..
can you hook up some parts
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
