CL-S conversion???
Old Sep 29, 2002 | 11:59 PM
vinniemack81's Avatar
CL-S conversion???
i have a 97 2.2CL.. and i heard that the CL-S engine conversion is a direct fit.. if anyone can give me any info on the conversion.. and where i can get a CL-S engine and 6spd tranny???
Old Sep 30, 2002 | 12:42 AM
dcsquirm88's Avatar
A CLS swap is not a direct swap into any first gen cl much less a 4 cylinder CL. The CLs engine and 6 speed tranny is going to cost easily over $5000 considering the 6 speed is only available on the '03 model. It would be a crazy waste of money and your would still have to custom fabricate mounts since you have a 4 cylinder CL and not a 6.
The swap you should be considering if any is an h22 swap. The h22 is the 200 HP DOHC VTEC engine from a '92+ Honda Prelude. Depending on what year or usdm/jdm model you get you can find a complete swap with ecu, 5 speed tranny and complete long block for around $2,000. Now this swap would be a direct bolt in except for the driver side mount and the your headers not lining up with the CL's exhaust.
In any case I think you need to do alot more homework before you go out and buy an engine. Try using the search function to find all the info you need.
Old Sep 30, 2002 | 01:14 AM
d5c5b's Avatar
DOOKS of hazard!!!!
wow....you told him!
Pham Alvan
May 18, 2021 06:48 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
HondoGermany
23
Jan 8, 2016 03:01 PM
RSpyder
Sep 30, 2015 12:46 AM
Gary Matthews
Sep 11, 2015 01:21 PM
