Cl launch control 2-step
Old Sep 4, 2008 | 10:48 PM
H22 euro R's Avatar
1 fastass CL
http://www.youtube.com/watch?v=97aekc-nrP8
http://www.youtube.com/watch?v=FPzvYs7GgDg
http://www.youtube.com/watch?v=Gh7m9R01Sr0
Old Sep 4, 2008 | 11:08 PM
Tehvine's Avatar
6spd FTW
Did you switch to boost or something? I don't see the point in a 2step on a NA H22
Old Sep 4, 2008 | 11:09 PM
DaInFaMMuS1's Avatar
Soon enough i'll get to spit fire like that...soon enough! lol. Looks sick bro
Old Sep 5, 2008 | 12:23 AM
lol are you serious? its called launch control.
Old Sep 5, 2008 | 11:38 AM
purple3.0haze's Avatar
i don't get it??
Old Sep 5, 2008 | 11:48 AM
AznX TL's Avatar
where is....
it revs to 4k or whatever you set your 2-step to, it was made for turbo cars as a misfiring system to build boost to launch, for n/a you dont really need it since you can just launch it without building pressure. but it looks cool
Old Sep 5, 2008 | 12:23 PM
swoleCL's Avatar
¿baCon?
launch control - - - I was doing some reading on the GTRs and the trannys can only hold 15 launches, thats from nissan!! Spend 65K on a car, that thing better launch me to the moon...
Old Sep 5, 2008 | 12:50 PM
bigT's Avatar
65k? That might be the MSRP, but you cant touch those cars for under 80-90k right now. IF you can even find one.
Old Sep 5, 2008 | 01:21 PM
Gnate's Avatar
Custom User Title
Originally Posted by purple3.0haze
i don't get it??
x2...
can somebody give me some information on this, like how you are spittin flames, and that looks harmful.
Old Sep 5, 2008 | 01:47 PM
the 2 step is used to hold it at a certain RPM to build power before you launch it so that you don't have to balance it at a certain RPM yourself which isn't easy. Its mostly used in turbo cars but plenty of NA cars have them too. Spitting fire is because of the straightpipe exhaust and his tune as an aggressive fuel mixture, the unburt fuel comes out as fire. I really dont see why people are freakin out about a 2 step on an N/A motor.
Old Sep 5, 2008 | 01:50 PM
Gnate's Avatar
Custom User Title
And how is it done? (No i'm not considering trying it for the record lol)
Old Sep 5, 2008 | 01:51 PM
Cocoa's Avatar
2600lb CL
You guys are getting all confused.
2 step and a missfiring kit are two completely different things.
2 step is used for drag purposes. It's a very convenient mod to have if you're drag racing all the time. You don't want to sit at the drag strip staring down at your rpms for that perfect launch and not have your eyes where you need them more, at the tree (the light signal at the strip).
With a 2 step, you set where you want your rev limiter to be for launching purposes. This is only for convenience so that you don't have to be staring at your tack for every run. If you know where your perfect launch is at, set the 2 step at the rpm of your choice, and floor it at every light. It will not rev higher than what you set it at everytime you rev it in neutral.
A misfiring kit (Anti-lag kit)is also another awesome tool to have (turbo'd car only). This allows for you to stay in boost while changing gears in every gear. It's purpose is to keep you at full boost for the following gear. If you driven turbo'd cars before, you'll know that there's a slight lost in boost going from gear to gear and you'll have to wait for it to spool up again. This costs you TIME at the race tracks.
A misfiring kit throws gas in your exhaust manifold, and the heat of the manifold combusts that gas, which then keeps the turbine spinning. This is why you see fire coming out the exhaust going through gears. BUT, a misfiring kit WILL diminish the life of the turbo faster as your turbo will run at hotter temperatures. (Don't quote me on this, but I believe the average raise in temperature in the turbo with this kit raises it 200 degrees F).
Old Sep 5, 2008 | 01:52 PM
Cocoa's Avatar
2600lb CL
Beat me to it. I kept having to walk out of the office typing what I was trying to get out.
Old Sep 5, 2008 | 03:03 PM
XxAtTheGatesxX's Avatar
Guitarded
two-steps are great. My buddies' got one on his civic.
Old Sep 5, 2008 | 03:07 PM
what is it just a box that you plug into the ECU. I really don't get why it has to backfire to hold rpm's
Old Sep 5, 2008 | 03:09 PM
AznX TL's Avatar
where is....
well it shouldnt really shoot out flames....he probably has his 2-step set to dump fuel to make flames shoot out.
Old Sep 5, 2008 | 05:13 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Man that's wicked, when it pops off it sounds like a machine gun poppin
Old Sep 5, 2008 | 07:28 PM
732xghost's Avatar
highly doubt it. his car was shooting flames when he was mildly modded.
sounds sick shuan. me and joe were amazed the other day on the way to the meet.
get ready for the typical AZ hate of this car being too loud.
Old Sep 5, 2008 | 07:45 PM
AznX TL's Avatar
where is....
is his car running rich? i thought the only ways to get flames to shoot out were to run a test pipe/straight pipe and to run a little rich, and to get flames out of a 2-step is to tune it to dump fuel or retard the ignition for fireballs?
Old Sep 5, 2008 | 09:12 PM
He's definitely running an exhaust with almost no restrictions, but i dont believe he's running that rich. I remember when i 1st started my swap with only the header on, it was shooting flames out the header downpipe. His motor is highly modded, which is why his has no problem making fireballs. And its tuned. Anyway you look at it, the car is sick.
Old Sep 5, 2008 | 09:41 PM
Tehvine's Avatar
6spd FTW
Ok well I could understand that then... I got thinking about that earlier today. I am just used to seeing people putting such a device on to build boost without romping the motor against redline.
But since you say this works in neutral, Euro R may I ask where you got the trigger for neutral? Was it just a negative trigger wire or what? That would be sweet if our car has a neutral safety switch so I can tap that to my remote start.
Old Sep 6, 2008 | 02:14 AM
732xghost's Avatar
nah i think hes running rich. he seems to have always been running rich.
i know ive been running rich since day one too. and i been told by friends that i pop the occasional flame, but not as frequent as shaun does.
BTW hows life as a 29 year old shaun? i hope to christ thats a typo. lol
Old Sep 6, 2008 | 02:24 AM
732xghost's Avatar
7th ave. imports. lol please.
we've been keeping the scene quiet over in south amboy. cant let perth amboy know to much but lets just say we got ourselves a little H22 craze here. and im not talking about mine and joes prelude cuz we hardly even count.
Old Sep 6, 2008 | 08:09 AM
ethenol's Avatar
Mom why is there two?
Is this just like a stutter box? I'm an old Mopar guy I used to have one on a couple of my cars.
Old Sep 6, 2008 | 10:57 AM
dragon084's Avatar
1999 CL3.0
"clack clack all day"
Old Sep 6, 2008 | 11:24 AM
(Mid-Atlantic)
I even saw his car shoot a flame when I was out there last year
Old Sep 6, 2008 | 11:30 AM
H22 euro R's Avatar
1 fastass CL
it's all in the chip. im using ob1 ecu with neptune program.
The 2 step and rev limiters are on an ignition cut. It cuts the spark instead of the fuel. The sound you hear is the fuel combusting in the exhaust because there is no spark to ignite it in the engine. There is black smoke because its not being ignited in the engine. Its actually less harmful on the engine than a fuel cut rev limiter that most tuning systems use. I am burning rich because im using 440cc injectors with my set up that's why.
Old Sep 6, 2008 | 11:41 AM
AznX TL's Avatar
where is....
nice,nice. did you launch at the toll booth or was that just to show the 2-step?
Old Sep 6, 2008 | 12:57 PM
He definitely didnt really launch at the tollbooth. No tires screetching or anything. That was just to show the 2 step. When he takes off, he TAKES OFF.
Matt what are you talking about "keeping it quiet"? I went to a shop in newark and saw some serious H22 bubbles. Tiny shop in a tiny street with a big speed secret.
Old Sep 6, 2008 | 04:38 PM
SupraManAG's Avatar
One custom CL
Whats your compression shawn? 440cc injectors are flooding your setup. Stock H22 injectors are 340smthing and even then you need to adjust your fuel trim not to run rich.
Old Sep 6, 2008 | 05:48 PM
732xghost's Avatar
Acura RDX injectors are the new thing.
Old Sep 6, 2008 | 06:13 PM
SupraManAG's Avatar
One custom CL
turbo applications require diff size injectors usually larger than n/a
Old Sep 6, 2008 | 07:30 PM
H22 euro R's Avatar
1 fastass CL
how is it flooding my setup? my compression 11.5 if i used stock injector its not enough fuel cause im maxing out the stock injectors. n plus that why when you do work to the motor you need to tune it so everything is right to get the max power.
Old Sep 6, 2008 | 10:12 PM
SupraManAG's Avatar
One custom CL
You are running rich thats why I have reason to say that ur flooding your setup. Let me see the page of your neptune. It should look something similar to this. This is mine currently.
Is that 11:5 compression from your Euro-R setup? Just curious?
I do know what the capabilities of a tune are. More fuel requires more air to compensate for the combustion or else you run rich. More air usualy means forced induction not naturaly aspirated.
Old Sep 6, 2008 | 10:27 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
My grandmas Cadillac does that..
So I guess she's cool? lol
Old Sep 7, 2008 | 12:11 AM
11:5 compression is from his internal work.
ghetto, if ur grandma's cadillac is doing that, she probably shouldn't be driving it lol. So no, she's not cool.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
adreano17
Sep 29, 2015 08:48 AM
navtool.com
Sep 25, 2015 05:15 PM
